Lumbar adjustment can not be saved to My Profile
Discussion in 'Model 3' started by flying_things, May 8, 2018.
  1. flying_things
    flying_things Member
    california
    Hi everyone,
    I found out my Model 3 can not save my lumbar position into my profile. It can be easily verified by adjusted the lumbar (the circle shape button that has four direction under the side of the seat) , and then tapped "Restore" button (besides my profile name) in the screen and the lumbar position don't go back to original place.
    This problem only happened on my Model 3 . (Model X doesn't have such issue). I just wonder if it is a software bug in Model 3 or some hardware issue of my car.
  2. buddhra
    buddhra Member
    San Luis Obispo
    Are you saving it after you adjust? You only have a few seconds to press the save button.
  3. flying_things
    california
    First I save it by press the save button . and after that, I adjust it to a different position and a "Restore" will be shown. normally, if you press the restore button, It will restore you to the previous saved position (like if you adjust seat recline angel, and press "store", it will move back to previous saved angel) . However, for "lumbar setting". It won't restore it for you, press "Restpre" and nothing happens.
  4. novox77
    novox77 1.21 Gigawatts
    NH, MA
    My 2014 S doesn't even prompt me to save when I change the lumbar setting. I just assumed it wasn't supported. But it sounds like it does save for Model X?
  5. Evthusiast
    Evthusiast Member
    Lumbar does not save for my 2013 model S. But I have an old car. Just thought it was a first gen thing for model S?
  6. buddhra
    buddhra Member
    San Luis Obispo
    Ok
    Ok, mine does the same. If I change the lumbar, it gives me the option to save or restore. If I press restore, it acts like it's doing something, but nothing happens. Looks like a bug report is in order.
  7. flying_things
    california
    "Lumbar settings" save does work on my 2016/12 Model X.
  8. flying_things
    california
    Thank for confirming!
    Maybe another bug on Model 3, would be great if you can also confirm that:
    If I try to change the telescope position of the steer wheel, the "Restore" button is grey out, so I can not even restore to my previous position.
  9. buddhra
    buddhra Member
    San Luis Obispo
    Yep, same here, but if I also adjust the steering wheel up or down, the restore button lights up and it will put both the telescope and the tilt back into my stored position.
