Piney999
What is the consensus? Will there be an AWD / P-model unveil? Or will it just show up on the website with some Elon Tweets? I keep hoping for an unveil, but probably not enough to say about it.
I doubt there will be any fanfare; trumpeting a Performance Model after the delay of the $35k car wouldn’t go over well with a lot of folks, IMO.
Things people have told me that won't go over well with a lot of folks:
-Not starting with the base 35k car
-Making some options standard on the first cars to drive the price up
-coming out with AWD before the base car
-selling to other countries (Canada) before selling the base car
-revealing another car, before the M3 production issues are solved. (Roadster 2)
-letting people that reserved the base car slip out of the full tax credit (Not sure if that actually will happen, but it looks like 200k will be hit in 2018 Q3, to end by the end of Q4 and I have heard some base reservations are now set for Q1 2019.)
Now since all of that has actually happened, I'm not so sure if that particular argument still counts.
The performance version will bring in lot's of cash and deserves a big fanfare. Also, they love to put on a show, especially with fast cars.
To add to that, the Semi and Roadster probably helped with model 3 production issues given the huge cash flowAs a later reservation holder (probably looking at a SR AWD), none of these things bother me at all. The one thing that drives me nuts is how some people are worked up with the fact that they are working on the Semi/Model Y/Roadster 2 instead of getting M3 production ramped up.
Tesla is a fairly large company. It can focus on more than one thing at a time. Moreover, engineering can be fairly specialized. So the Engineers working on designing new vehicles are probably not the same engineers focused on building the manufacturing lines and likely don't have the expertise in that area to help even if they wanted to.
Sure those other things to cost money, but probably a drop in the bucket compared to the ramp up.
But the performance model is simpler to test really than the plain AWD. You just put a small motor in front. For the plain AWD you have to put a small motor in front AND test a new small motor for the back. Especially aince the LR battery doesn't change
Anyone think that P could just be a software difference from the plain AWD?
Agreed. Although the evidence is mounting that the current S/X drive units are nerfed for some future uncorking 2. I am anxious to compare the 3 back EMF high speed passing torque and power data.@Krash ...I think Model 3 P will likely have the same power levels as a Model S90D (~370 KW), but with half a ton less weight it will be quite a bit faster. (3.5s 0-60)
I think they can only unlock performance not lock it, based on the P90 attempt and backlash....They can gimp it as much as they like via software...Personally I would prefer...a tiny and highly efficient front motor which is just designed...with torque sleep.
Elon never said there will be a P variant for the Model 3. He said there will be a Lubricous mode option. It could be a software-only option for the regular LR AWD.
Model 3 current production uses Permanent Magnet Switched Reluctance motor (PMSR), not a true permanent magnet motor. The small permanent magnets are only used to smooth out the reluctance motor's inherent torque ripple. You can torque sleep this motor, though not quite as efficiently as an induction motor.
However, PMSR motor has an additional limitation at high power levels -- magnetic saturation in the rotor. In an induction motor, if you want more torque, you can just massively increase applied frequency and/or current with the inverter. The motor temperature increase may require that you reduce power some seconds later, but for a brief period you can get massive torque.
PMSR motor can't do that -- if you drive the rotor to magnetic saturation, torque falls off and goes to zero. Additionally, PMSR motor doesn't have a very high stall torque (torque @ 0 RPM), making it less suitable for a P variant of the Model 3.
My predictions:
1. For cost reduction, AWD model uses two of the same PMSR motors as the RWD model, no smaller version needed. Performance slightly better than RWD model, but no more than 0.3 sec 0-60. Main advantage is snow/ice handling and possibly ride quality due to rumored inclusion of air suspension.
2. Performance model uses different motor in the rear -- possibly an induction motor. High torque off the line means lower 0-60, I'm going to guesstimate 3.9 sec 0-60 to compete with BMW M3. PMSR motor in front enables very high efficiency when cruising.
