32A single phase, 3 x 16A 3 phase.
Have you manually adjusted the current in the charge screen of car?
The right number gives the max current that the charge point is offering. If its less than you expect, its likely to be a charge point issue. Not all charge points will be set to the max. There may be several reasons why its been de-rated by installer. Or a fault.
So what does the right hand side number say?
To be fair it says "limited" to 20amps rather than not capable of more. and says there is stuff about deactivating the limit on page 20 so it may still be fixable dependant on what is on page 20. but sounds like it will def need a visit from the installerI doubt there's a charger problem, as the car seems to be behaving normally, but it's quite possible that the charge point has been internally set to only signal to the charger that 20 A is available. Several models of charge point have this ability, often adjustable via an internal DIP switch, or perhaps a small screwdriver operated rotary switch.
Looking at the MIs, it seems that the Webasto Pure has a DIP switch internally to set the max available current that's signalled to the charger via the control pilot connection, although there doesn't seem to be a 20 A setting. There is a note about the unit only being capable of 20 A though, when it's a 22 kW (3 phase) model connected to a single phase supply. This is the page from the MIs:
I'll have the installer stop back. This has been helpful.
I must say no amount of youtube videos can prepare you for the actual car.
I can't increase it past 20A but when it's charging it sometimes flashes 21A.
I might have to get the installer back.
He originally installed it for a BMW i3 and then transferred it over to my charging spot one space down.
Amongst all the relevant replies I didn't spot anyone specifically confirming that the SR+ charges as fast as any other Tesla on AC charge points ... so at home on a single phase supply you can expect 32amps 7+ kW
You definitely need your installer back.
I get 8.2kWh on my single phase eo mini when charging my sr+ so the car is definitely not capped
I had this with a ChargePlace Scotland charger the other day - the car locked the maximum charging at 20A - I let it charge for a short while thinking it might increase - it didn’t, stopped it, unplugged and then plugged it back in again and it let me increase to 32A.
From looking at part numbers, it looks as if the AC charger is common across all UK Model 3s, so AC charging should behave in the same way irrespective of model. DC charging may well behave differently, because of the change in battery capacity between models, but DC charging uses a charger that is external to the car, with the car signalling to the external charger, opposite to way in which AC charging works. AC charging works by the external charge point (which is just a power outlet and switch, in essence) signalling to the charger (which is in the back of the car) the maximum AC supply current that is available, and the charger then varies the demand to comply with that set limit, and keep the charge current below it at all times.
My money is on the DIP switch being set for 3 phase, 32 A, in error, as this would give a default 20 A max, according to the Webasto Pure MIs. I bet that changing the DIP switch to the 32 A, single phase, setting will fix the problem and give you the full 32 A.
You do get to keep your cash as you were spot on.
