M3 test-drive: turn-signals and the head-rest
Discussion in 'Model 3' started by acal, Sep 3, 2018.
  1. acal
    acal Member
    Santa Clara, CA
    test-drove (and ordered) a 3 yesterday. We recently got an X and I was quite surprised by how differently it drove.
    First irritating thing...the turn signal. Why does the stalk not stay put when you use it to signal left or right? I get that the turn-signal continues to be on after just a quick bump, but I miss the tactile feedback to know that it's on/off. More than once I only knew the turn-signal was still on because I could hear it and had to look to tell which way to flick the stalk to turn it off.
    Second item - the head-rest is not adjustable. Was ok for me, but DW felt like it was way too far forward. I'm really surprised it's not adjustable. Anyway else feel like it's pushing their head forward?
  2. Hotlobstah
    Hotlobstah Member
    Cape Cod
    The turn signal is kinda funny but whatev(as in it's really not that bad)...they'll tweak it as time goes on. The seats are super adjustable and there is absolutely no reason for you to feel like it's pushing your head. Some of the seat adjustment controls have multiple functions...it sounds like you may have the seat tilted to far forward or something.
  3. run-the-joules
    run-the-joules Active Member
    SF Bay
    The turn signal returns to home position because that reduces complexity and allows auto lane change to turn off the signal. Despite not having ALC, newer BMWs are also like this, I believe.
  4. thewishmaster
    thewishmaster Member
    VW has had this for a while as well. I remember seeing tons of complaints when BMW introduced this functionality for the first time (possibly in the E6x/E9x generation) ... It's quite intuitive once you use a few times. Don't have my Model 3 yet but I'm glad to hear this is the implementation :D
    Does the Model 3 have a 2-stage blinker as well, where it flashes the appropriate blinker 3 times if you half-press the stalk?
  5. run-the-joules
    SF Bay
    Yup.
  6. timk225
    timk225 Active Member
    Pittsburgh
    Headrest does make it hard to lay back into the seat, it pushes my head too far forward with no neck support.
  7. Hkbruin
    Hkbruin Member
    Laguna Niguel
    The stalk will stay, you’re just not pushing down hard enough/all the way. I don’t like how it doesn’t go back after you complete the turn.
  8. jamnmon66
    jamnmon66 Member
    Brighton, CO
    No it doesn't. Not a problem IMO but that's how it works.
  9. KenF
    KenF Member
    Washington, DC
    IMO, all Tesla needs to do is add a slightly different sound for the right and left blinkers.
  10. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    Indeed. The turn signal returning to its home position means that Tesla won't have to insert a solenoid or some kind of additional complexity to physically return it home.
  11. Hkbruin
    Hkbruin Member
    Laguna Niguel
    Oh I see what you mean, the stalk returns to position but the turn signal remains on until you manually turn it off. Yeah that’s strange now that I think of it.
  12. SomeJoe7777
    SomeJoe7777 Marginally-Known Member
    Houston, TX
    Turn signal was designed like this intentionally because FSD needs to initiate signal and cancel signal completely on its own. If the turn signal lever was mechanical like classis turn signals, then additional hardware and circuitry is needed.
