I have replicated those settings and will see how we get on. It was at 81% earlier today. Hoping that when I check it tomorrow morning it is no lower than 80%.
You can check the TeslaFi logs to confirm when it is polling or not. If TeslaFi is not polling, it should not have any effect on the car sleeping except for delaying (default 30 mins) the car counting down to sleep (typically up to 15 mins)
I’m having the same issue. I’ve checked everything and tried the suggested fixes on this thread several times and I’m still losing 10% of the charge overnight.
You shouldn't lose that amount on TeslaFi. If you do have TeslaFi, its your friend - pull the logs and see if its reporting anything unusual.
Sentry mode or Summon standby setting most likely if car should be locked and parked. But other things may also be causing it. Even keep checking the app!
I think you have the mirrors set to tilt on reverse. Can't remember where it is but probably below the screen on one of the set up pages where you have to swipe up. Caught me out for a while hiding the pages below.
