I have been researching these forums for some time, now registered and researched even further but there is so much advice that just conflicts each other it's crazy.
Car = Model 3 Performance 28k Miles
Can I just double check the very best options here -
Scenario, I have a home charger, can charge to 100% every night if required. Daily use is around 25%, so is it better to charge every day to 80%, or 90% or even 100%? Or is it better to run it down daily until like 20% and then go back to 80/90%?
I've never flicked the percentage over to miles, so I have got no idea what the max stated range is, but is this the best way to determine the battery health? If so, what sort of miles should I be looking at for 100% charge? If needs be, I'll do the reset procedure as I've only had the car for 2 weeks, the first 27k miles have been the original owner so I am unsure if it's calibrated properly etc.
Thank you all -
Thank you all -
