Hello,
I’ve seen a lot of posts discussing the improvements in 0-60 times, range, noise, ride softness, and protection against hazards with smaller wheels.
I need to switch to Ultra High Performance A/S tires once my M3P is delivered since we see below freezing temps in Delaware in the winter.
I decided to get 18x8.5s with 235x45 Pilot Sport AS 4s but I’m debating if I should run a setup with wider tires and larger wheels.
I specifically want to know:
(1) What degradation did you see in cornering and overall handling after switching to smaller diameter, narrower wheels on the M3P?
(2) If you went with wider wheels and tires what improvements did you see in cornering and handling?
(3) Did the improvements in range, 0-60, and ride comfort outweighs the reductions in cornering and handling? Or vice versa if you opted for a setup that didn’t favor range and comfort.
All this is assuming that smaller and narrower wheels do in fact reduce cornering and overall handling.
Like I said , I pulled the trigger on 18x8.5s with 235x45 tires recently and I’m debating if I should cancel my order because I enjoy sportier handling more than I want efficiency and comfort. I’m thinking about getting 19 or 20s with wider wheels and tires.
