This has been covered but there’s no consensus. I am currently running 3 up front and 5 in the rear. I am running Forgestar 20 inch wheels.
I ordered some 15mm spacers and tried to fit them on the rear. Unfortunately they don’t clear the lugs which I thought wouldn’t be an issue since the wheels are aftermarket.
So it appears I need 20s on the rear.
What options will I have for the front? If I try the 15mm up front will I have the same clearance issue as the rear? Or is the front hub different from the rear such that 15mm should clear?
can anyone recommend a set of 15/20 mm spacers that will fit a M3P? This has been difficult to pin down. Is 15mm too much poke up front?
Thanks.
Thanks.
