After checking into things, I ended up getting a custom set of 8mm spacers made from traverse ridge for the rear wheels on my M3P. In Pa, anything over 8mm is illegal so I stuck with 8. There are not bolt on.
Based on my reading here and elsewhere, the M3P should be able to support up to 8mm spacers due to the increased lug length versus the LR. Just want to be sure I am not subjecting the car to any undue risk of damage. Traverse indicated others are running 8mm without issue although they said 8 is the max. Thanks.
