M3P vs winter tires - in Boston, MASS
Duke9th
47
20
Mass
Could anyone give me a piece of advice whether I need winter tires for my M3 Performance 20" wheels? if so what type? - Thank you in advance : )
MNScott
5
6
Minnesota
Yes, you absolutely will. The tires on a M3P with 20" rims are SUMMER ONLY. Most folks drop down to 19" rims and get a good winter tire - Nokian R3's, Michelin X-Ice are popular choices.
Scott
Reactions: Duke9th
TrumpetTitan
Model 3 Performance
May 17, 2018
44
17
Baltimore
Personally I would strongly recommend winter tires. However, if most of your driving is going to be in a city/metro area where the roads are regularly salted and plowed, AND you have experience driving a car with all-season tires in snowy conditions, AND your factory tires still have lots of tread depth, I would say you don't "need" them, so long as the roads are regularly treated in time for you to get where you need to in the case of significant snow/ice.
I'd say the price of a set of winter tires like these is worth the peace of mind that you won't find your prized Model 3 in a slippery situation.
https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Pilot+Alpin+PA4+N-Spec&partnum=335VR0PA4XLN0&vehicleSearch=true&fromCompare1=yes&autoMake=Tesla&autoYear=2019&autoModel=Model 3 Performance&autoModClar=
These tires cost less than your factory tires, so the cost of tire wear will be less for your winter miles.
Reactions: Duke9th
MNScott
5
6
Minnesota
The 20" tires on the performance model 3 are most likely a Michelin Pilot Sport 4S (PS4S) and they should not be used below 20F. As reported in another venue: "However, Michelin notes that its summer tires—specifically the PS4S—are not recommended for use in the cold. When Michelin's summer compound tires are exposed to cold air below 40 degrees, the tire compound stiffens and loses pliability, and the grip level can degrade. As temperatures dip below 20 degrees, the tire's surface area may begin to crack due to improper exposure and use—and those cracks would void the warranty."
Reactions: Duke9th
Timberwolf
19
5
CT
I'm still waiting on my bloody car. Big delays due to the Euro deliveries. I have an MP3 coming and I ordered these 18" wheels. I'd rather have maximum tire wall for potholes, plus it will be an acceleration aid.
Tesla Model 3 18
MightyHawk
52
57
Boston
It sounds like you got the Model 3 Performance with the Performance Upgrade Package (including bigger brakes). If so, you need to be very careful about which wheels you buy if you get a spare set of wheels for the winter tires. Tesla's 19" wheels don't fit without modifications. Only their 20" wheels do.
On the other hand, TSportLine has even some 18" wheels that were designed to work with the Performance Upgrade Package.
mswlogo
6,117
4,733
MA, NH
Thank you everyone for your input. it's very helpful : )
Better get cracking 21F Friday night. It’s not just about traction, you will ruin the tire and void the warranty on them.
You can also get the Performance snows as well from Tesla. But Tesla only offers those in 20”. Folks have found even 18” aftermarket that will fit. You really don’t want to run 20” on any winter tire.
TSportline sells complete packages.
There are trade offs for each tire you should really understand.
brianman
Burrito Founder
Nov 10, 2011
17,535
3,004
Yup. I have these on mine, currently with Continental DWS 06. I'll probably replace the tires with Michelin Pilot A/S 3+ due to preference (and habit) but no complaints about the Continentals.
neezer
244
1,373
Boston
Ordered a set of Conti Viking 7. Should be installing in a couple days. Yes, I have the 20" Michelin 4S right now. Can't do that in our winters!
Reactions: Tommi
Rachmaninov
220
146
NJ
In today’s environment you would probably be blamed for ANY accident you’re involved in if you’re using tires outside of their stated safety temperature range. It’s amazing how some people think it’s never their fault and you must be at fault.
Joe85sti
75
92
Massachusetts
I have a M3P on order, and just purchased a set of 18” wheels with a set of general altimax snow tires, all for less than $1,300. You definitely do not want to be driving the the summer tires in the cold, never mind any type of snow on the ground.
