Mach E RWD range 370 miles
Discussion in 'Electric Vehicles' started by MARKM3, Feb 13, 2020.
  1. MARKM3
    MARKM3 Banned
    Raleigh
    Ford Mustang Mach-E Debuts In Europe With Special Tuning
    "Equipped with the larger battery and in rear-wheel-drive guise, the electric crossover promises to cover 600 kilometers (373 miles) based WLTP, which is a more realistic test cycle replacing the old lab-based NEDC."
    "The Model 3 long Range AWD has a large WLTP range of 544 km (338 mi). The Tesla Model 3 Performance naturally also has AWD thanks to a dual engine and sprint in 3.5 seconds from 0-100 km / h."
    What do you all think? Is this comparable?
    • Disagree x 1
  2. YusufT
    YusufT Member
    Toronto, Ontario
    Read the article and it says they promise to reach that in the WLTP test, not that it's what they achieved unless I'm blind.
  3. MARKM3
    MARKM3 Banned
    Raleigh
    Yes it does, will be interesting to see when the testing is complete.
  4. Big Earl
    Big Earl Supporting Member
    Springfield, VA
    I'd expect maybe 300 miles real world range. Both WLTP and NEDC are very optimistic with regard to range.
  5. ElectricIAC
    ElectricIAC Devil’s Advocate
    DFW
    300 EPA, 200 RW best case.
  6. TJKR
    TJKR Member
    370 miles is not a problem... if you go 30 mph.
    Model 3 went 600 miles at 30 mph.
  7. ElectricIAC
    DFW
    I’m down to do that test as soon as FSD can reliably stop at red lights, stop signs and yield properly at other at grade crossings.
  8. MARKM3
    MARKM3 Banned
    Raleigh
    What makes you say that? The model 3 is only slightly less than WLTP range
  9. ElectricIAC
    DFW
    It’s not 70 and sunny and calm everywhere so those numbers are meaningless.
  10. MARKM3
    MARKM3 Banned
    Raleigh
    I was just wondering if there is a reason that test would be more biased towards the model 3 having better range EPA vs the Mach E. Why would the Mach E only get 200 EPA and the Model 3 retain 95% of their WLTP range?
  11. ElectricIAC
    DFW
    One could argue the same point about the Taycan.
  12. MARKM3
    MARKM3 Banned
    Raleigh
    The Taycan EPA is 192 miles. Is it worse than that IRL?
  13. ElectricIAC
    DFW
    I hear better.
    The point being is, they can report whatever set of numbers is most convenient to their cause but what matters is what the end consumer sees.
  14. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Given a 100kWh battery and compact size, it seems reasonable.
    What's the price on the 100kWh version?
    Of course, this is Ford, the company whose Fusion and C-Max hybrids "achieved" 47mpg until they didn't.
  15. MARKM3
    MARKM3 Banned
    Raleigh
    $45,000 with the Tax incentive, add 7.5k without it.
  16. TomB985
    TomB985 Member
    Isanti, MN
    This is awesome.
    The more legit competitors we have, the better things will get as consumers. That would force Tesla to improve their technical and customer service game. I think we already have the best car on the road, but it has to get better when that’s no longer the case
  17. AlanSubie4Life
    AlanSubie4Life Efficiency Obsessed Member
    San Diego
    #17 AlanSubie4Life, Feb 13, 2020
    Not really. The 544km result is from a year ago, and is for an AWD vehicle.
    If you really want to compare, I guess you'd have to try to extrapolate and project from the LR RWD.
    Roughly speaking, the LR RWD if retested today would get at least 340 EPA miles. (Just extrapolating from the SR+ RWD improvements - we don't have a real EPA test to go off of - all we know is it's at least 330 EPA miles before the efficiency improvements.)
    So if you scale that up roughly:
    544km * 340EPA / 310 EPA = 597km.
    So it seems pretty similar. Sounds like that would be from a 98.8kWh pack vs. the Model 3 LR RWD which is about 79kWh to achieve that result.
    So maybe the Mach-E is 20% less efficient - not too surprising since it's a less aerodynamic shape than the Model 3. But it looks like it would be less efficient than Model Y as well.
  18. VT_EE
    VT_EE Active Member
    Maryland
    I hope it’s true. Elon will be motivated to increase Model Y battery capacity and range.
  19. ItsNotAboutTheMoney
    Maine
    It's OK. I looked it up. It's $52.4k + delivery ($1.1k) - credit.
    Target EPA range for the "RT 1 edition" says 300 miles.
    For some strange reason there's no 100kWh AWD version listed, but there are AWD versions listed for the 76kWh versions. Probably not strange, since 280 miles wouldn't give any headlines.
    I guess that's why they called it the RT 1 edition.
    For the 76kWh, $43.9k for RWD not too bad. AWD adds $2.7k and knocks 20 miles off the target range (210 v 230).
    But of course, if you want heated seats and mirrors you have the copy of the Tesla bullshit, and have to pay $6.7k, and for part of that money, they'll cut your range by giving you 19" wheels instead of 18".
    Neither of them are efficient, but nobody cares about efficiency, so it won't hurt sales, and I think they should be able to sell as many as they need to import.
  20. JohnSnowNW
    JohnSnowNW Active Member
    Minnesota
    Only Tesla doesn't show a 15-30% difference between WLTP and EPA range figures.
