After looking a bit more at the Chinese made car and comparing it the Fremont version I've noticed that on the Chinese car the bottom half of the door cards are made from hard plastic whereas on the Fremont car the door cards are made from padded plastic. In particular, looking at the inside edges of the back doors when open, the door card plastic is very thin and a lot lower grade than even the cheapest Ford or VW (for example). A subtle difference but another piece of cost cutting. I suspect there will be more if I looked deeper.
Question is; does it matter? Overall the car is better and now I've seen several, all of which are identical in fit/finish, it is a vast improvement. However, I do wonder about long term durability if less obvious components are lower grade in a similar manner to the door cards and seats...
