Made Mistake - Tire max pressure below tesla recommended
Discussion in 'Model S' started by Pipcecil, Aug 28, 2018.
  1. Pipcecil
    Pipcecil Member
    Midlothian, TX
    So I recently had to purchase two new tires for my Tesla. I purchased it as a CPO a couple of years ago and this is the first time I have had to replace any tires. I did my research, Tesla would not offer any low rolling tires (only the goodyear eagle touring) so I hit up my local Costco and got some Michelin Premier A/S. Great reviews, sporty tire with low rolling, what more could I want.
    Well, since this was never an issue for any of my other cars, these tires have a max manufacturer tire pressure of 44 psi, lower than what Tesla recommends at 45 psi. This was something I never thought to look for (none of my other cars I ever owned had anything beyond 38 psi recommend by the car). So now I don't know what to do.
    What happens if I keep the cold pressure at 45 psi on these tires? What if I keep the tires at 44 psi below Tesla specs (FYI these are on the rears so I think any pressure differences would be more noticeable here). Is this 1 psi going to give me issues? Should I just use Costco's generous return policy and get some tires that have a higher max PSI and fit what I want (looking at reviews and what Costco offers, it would probably be the Bridgestone Turanza Serenity Plus)? Granted the Michelin Premier A/S are supposed to be outstanding tires, but I am a little worried about the mis-matched PSI.
    Thoughts?
  2. dark cloud
    dark cloud Member
    BC
    I checked my local Costco and I don't even see the premier available in Tesla size at my store; just the Primacy's.
    I wouldn't worry about it, 1 psi is negligible. The tire pressures change from 45 to 53 psi on a daily basis during driving in hot weather. If people do not adjust their pressures every season the 45 psi could easily become 42 psi as the cold weather arrives. I would wager this is over 75% of the population.
    The more important consideration is the load index, or service description, and the only 245/45/19's I see for that Primacy on Tirerack is 98V. I assume Costco has the same tire, and If you like the tires (and I can't imagine you wouldn't) I would set them at 44 and forget about it.
    https://www.tirerack.com/tires/tires.jsp?tireMake=Michelin&tireModel=Premier+A/S&sidewall=Blackwall&partnum=445VR9PREAS&tab=Sizes
    Edit: And I had Turanza EL42 s as the OEM tires on the Infiniti we had before getting the Tesla; they were horrible tires; every bump had them bouncing all over the road. I know they are different than Serenity's but I will never own any tire that says Turanza ever again.
  3. Jrzapata
    Jrzapata Member
    Texas
    Don’t worry about 1 psi. Elon recommended to lower the psi by 10% if you want a less bumpy ride once. Follow the manufacturer recommendation in this case, it might be safer
  4. .jg.
    .jg. Member
    Weston Super Mare, England
    Michelin apparently recommends tyres with higher maximum load figures for the Model S. However, Michelin quotes the Premier A/S as having a maximum load for a single wheel of [email protected] ([email protected]) and I reckon that is comfortably more than the per wheel loading for a fully laden Model S with 48/52 weight distribution. Like the other guys said, I wouldn't worry about 1 PSI.
