You are using an out of date browser. It may not display this or other websites correctly. You should upgrade or use an alternative browser.
The main house fuse is burnt and causing pulsing lights in the house. Also, the Wall Charger doesn't work.
I got my Model Y in August. I had a Tesla Wall Charger installed with 60 amp breakers and was charging at 48 amps.
Hawaiian Electric inspected the main fuse box and said it is deteriorated and should be replaced. The electrician says that main fuses last about 25 years in Hawaii. My house is 35 years old. I feel that the Wall Charger caused the deterioration. I should have used a lower charge setting.
I am using the mobile charger to charge off a wall plug on a different circuit until the fuse is fixed.
So if you are in an older house, you should not charge at the highest rate.
