Main (middle) screen shut down during a charging session!
Has this ever happened to you?
  • Yes
    Votes: 16 57.1%
  • Yes, but not during a charge session
    Votes: 4 14.3%
  • No
    Votes: 8 28.6%
  • Total voters
    28
David29
2,469
2,126
DEDHAM, MA
I clicked "yes," but as I recall, the screen rebooted once I opened the door. In other words, just sitting in the car during the charge did not keep the car "awake." But once I opened a door, it came alive. This was a year or so ago, so my memory of details is fuzzy.
vandacca
ReActive Member
Oct 13, 2014
3,371
2,251
Hamilton
it wouldn't even let me reboot...it was stuck.
it seemed to have a mind of it's own for about 3-5 minutes.
It's entirely possible that it couldn't reboot while it was charging (eg software won't allow a restart due to requirement to monitor your charging). You would need to perform all sorts of experiments to verify and figure out why, but reproducing it may be difficult now.
Of course, there is probably some engineer at Tesla that would know why, but trying to find that person would be a challenge in itself.o_O
Reactions: Peteybabes
Peteybabes
redneck drivin' a tesla...
Apr 8, 2016
1,235
712
'murica
thanks for this.
ok, so my car was parked in the heat all day, but i had turned on the app 10 minutes before i got in, to get the interior temp from 104-106 degrees down to 68. Once i jumped in everything was working fine, drove about 10 minutes of this DC Chademo Charger which is in an underground parking garage, (hence the cave like lighting in the video), where it was in the 70's temperature wise.
I had been charging for about 15 minutes when this system conked out...
David29
2,469
2,126
DEDHAM, MA
In nearly two years, I have had the center screen spontaneously reboot very few times (3 or 4 times, perhaps), and several other times it has required rebooting for one reason or another. And I have had the screen shut off while I was charging and in the car. As I mentioned above, I recall that the computer did not actually seem to be "off," it is just that the screen went dark after a few minutes of charging. All I had to do was to step on the brake or open the door and it came up again, not a reboot. I think it must have a time-out function if there is no activity even with a driver in the seat.
Just this week I had to reboot the center screen because the audio would not play and navigation was unresponsive, after having the car parked for 20-25 minutes. Once rebooted, all was normal.
I've rebooted before while charging and it works. The gateway will remain powered to monitor the charging while the CID reboots.
thanks for this.
Keep in mind that the heat and the fact that this happened to you while charging could be red herrings. It may not have had anything to do with these conditions.
What is concerning is that it took so long for your screen to respawn. While I have had this happen under various conditions in my car, it will restart with seconds to no more than a minute.
Reactions: vandacca
