Thanks guys.. that is definitely what happened. I was asked for $3600... then my astonishment led to a call for $1200 as the fee. I definitely paid it. At the San Diego service center. I did not buy the service plan.. so this is the fee I was asked 'to catch up, since you haven't done any service yet.' Here's a copy of my invoice.
Concern: Perform 6th Annual Service
Corrections: Annual Service
- Pulled logs and checked for active faults: No active faults (05/07/15) - Checked firmware
version: Updated to latest version 6.2(2.4.197) - Performed function check of closures
(moving glass, doors, trunks): Cleaned and lubricated latches. Good, no issue - Tested
and inspected customer¶s charge cable: Charge cable not present - Replaced: - Wiper
Blades - Key Fob Battery - Cabin Air Filter - Air Conditioning Desiccant Filter - Remote
Keyless Entry: Good, no issue - Seat belts and latches: Good, no issue - Interior/exterior
lighting and horn: Good, no issue - Performed inspection of powertrain and chassis
components: Good, no issues. - Checked fluid levels: Topped off washer fluid. Brake and
coolant levels optimal. No signs of leakage - Performed Brake Fluid Exchange - Performed
Coolant Exchange - Inspected tires and rotated as necessary - Measured tire tread depth
at: (Outer) (Center) (Inner) LF: 6/32 6/32 5/32 RF: 6/32 6/32 5/32 LR: 8/32 7/32 7/32 RR:
10/32 10/32 10/32 - Adjusted tire pressures to B-pillar spec: 45psi Front, 45psi Rear -
Measured brake pad thickness (mm) LF: RF: LR: RR: Park: 6mm 6mm 8mm 8mm 5mm -
Performed 4-wheel alignment check - Test drive: Vehicle functions as designed
Total Labor & Miscellaneous Items: 1200.0000
Pay Type: Customer Pay
