I've read some other posts and it sounds like the HV battery may be bad?
Could it be just the cheaper 12V battery and not the main battery?
I can't speak to that - They want me to have it towed to Memphis (3 hours away). If it's just that battery then great. But the car was VERY unhappy. The car stayed on for about 15 min but once it shut down, no getting it back on. Does a 12v failure act like that? The drive system completely shut down - no more go go. Thanks!
Second question - has anyone had any luck getting major things covered this close out of warranty?
You know it's a 12V battery when the accessories are weak or non-existent such as the volume of a dying horn, dimmed headlights, dimmed cabin lights, screens are blacked out. You might want to get a voltmeter to plug in your cigarette lighter next time to see whether the 12V still holds enough voltage.
If you want to ask if you can pay for the ESA (Extended Service Agreement--"extended 'warranty'"
"What is the eligible purchase period for Tesla Extended Service Agreements, and what do they cover?
You may purchase the Extended Service Agreement no later than 30 days or 1,000 miles past the expiration of your New Vehicle Limited Warranty."
You could search Youtube for how to jump start your 12V battery. That will help you determine if the cost is equal to 12V by ruling out 12V has the problem. Some year cars are easier to get to the terminals than others. So, I;m not going to explain how to do it.I can't speak to that - They want me to have it towed to Memphis (3 hours away). If it's just that battery then great. But the car was VERY unhappy. The car stayed on for about 15 min but once it shut down, no getting it back on. Does a 12v failure act like that? The drive system completely shut down - no more go go. Thanks!
The ESA doesn't cover the battery unfortunately.
I haven't done that. But, I'd have to drag it (literally) to my charger. It won't even come out of park.Basic question: when you put the car - not the 12v battery - on charge what happens?
It sure sounds like the 12v battery is dead. Here how to get the car in neutral with a dead batteryI haven't done that. But, I'd have to drag it (literally) to my charger. It won't even come out of park.
The displays are turning on now. It's showing the main battery at 98 miles. I'll go put it in tow mode... not sure if I should put it on the charger. I'm waiting to see what the service center has to say.It sure sounds like the 12v battery is dead. Here how to get the car in neutral with a dead battery
How to put a dead Tesla in neutral or tow mode
State Trooper friend just texted me at the scene of an accident where Tesla was totaled.forums.tesla.com
Then you need to get the car on charge, the main battery is most likely at 0% SOC.
No, I guess not, else I would not have replied. I will add you to my list. Thanks for the reply.Is that not what I did (see my last post)?
There's no reason not to connect it to a charger. I'm assuming you mean a charger for the high voltage battery. If it won't work, the charger won't turn on. It requires bidirectional communication. If the battery management system reports an error, it won't charge. So, I'd give it a shot!
Might be that the car has to be in Park (?)Got it into tow mode and was going to try it but the charger port won't unlock. The door opens but the lock is preventing it from accepting the cable. Good times.![]()
