Major system failure after car wash
Discussion in 'Model 3' started by Mash, Mar 31, 2020.
  1. Mash
    Mash Supporting Member
    Prague
    #1 Mash, Mar 31, 2020
    I don't know if anyone had this thing:
    UPDATE: It was damaged speed sensor cable.
    So I installed summer wheels with new tpms, adjusted somewhat wheel sensor cable to not touch the rim, actively washed a car and 10 minutes later after acceleration on a highway suddenly got all that.
    I don't have access to any working Service Center for next month. I suspect flooding, wheel sensor or cable disconnect. But for wheel sensor I don't understand tpms and steering assist failure.
    Maybe somebody saw similar issue?
    P.S. Restart, reset, power cycle, and even update 8.1->8.2 didn't change that - it happens right after I press the brake pedal to start a car.
  2. smartypnz
    smartypnz Supporting Member
    Monterey Peninsula
    My guess would be loose or disconnected cable which got wet
  3. TLLMRRJ
    TLLMRRJ Active Member
    Houston
    I think that's what your screen looks like if you put it in "dyno mode." Doubt you did that though.
  4. cOoTeR
    cOoTeR Member
    Arizona
    Here is what I had pop up when my wheel speed sensor wiring rubbed on the drive unit and would short out occasionally. Powering off the car would get it to go away for me. Service center just spliced in a new section of wire to replace the bad section in the harness. If yours is constantly showing the error I'm guessing it's going to be a broken wire, a wire that it's worn through and constantly shorting out or a disconnected clip somewhere. That's assuming the car has had plenty of time to dry out.
    What kind of car wash did you do? High pressure water could have moved something around and caused it to short or gotten into a harness.
  5. HelloAngeles
    HelloAngeles Member
    Los Angeles, CA 90042
    Nerver happend this on my car , maybe loose or disconnected cable which got wet . same point
  6. mba83
    mba83 Member
    Portland, OR
    Wheel speed sensor for sure. Bad connection or damaged sensor.
  7. derichio02
    derichio02 Member
    I had a sensor for seatbelts that came unplugged and basically the car shut down many systems. Sounds like it’s a severed connection as someone posted above
  8. Mash
    Prague
    Thanks. It looks very similar except TPMS. It was high pressure wash and later I found tons of rust fell out inside of rims. Car should have dried by now - 3 days. I also wiped water that gone under the hood tray.
  9. Mash
    Prague
    I will check them for sure, new wide wheels might have destroyed them. Not sure why tpms though.
  10. Mash
    Prague
    Wheel sensor after new wheels installed. 275x35x19 on 19x9.5 mpss4s. One destroyed, another close to that. How to move cable?
    • Informative x 2
  11. Mash
    Prague
    Apparently, with wider wheels and lower suspension you must slide rubber holders on wheel sensor to not end like that.
    I carefully fixed cables with soldering and bunch of shrink tubes and issue solved for now.
    Why on earth Tesla reporting TPMS failure instead of wheel sensor is beyond me. A bug? Because there is no tpms failure...
    And they disable steering booster, I guess, to discourage you from driving without abs or esp or regen.
  12. Sophias_dad
    Sophias_dad Supporting Member
    Massachusetts
    Wonder if there's an antenna-function either in the harness or at the end of it. There's got to be something fairly close to the wheel to pick up the TPMS signal.
  13. Mash
    Prague
    TPMS receiver or antenna is not there.
