2018 Model 3, LR, Dual Motor, FSD, 89K miles, 2021.24.4
On the East Coast and traveling to/from midwest the exists aren't always smooth, it's a hit or miss, and not fun when a car is trailing you off the exit and you going ricocheting down the exit. Sometimes accelerating and then quickly decelerating and you dive right then left before settling. Other times it takes the exit fine. However if there is an exit that goes to two lanes when you enter it look out, no telling which lane it will pick and you will get flung when it makes an abrupt decision. There's a couple on rte 78 in NJ, sometimes its fine and other times hang on. Best to just shut it off before the exit. It also can not handle when an exit is after an on ramp and they share the same lane merging. It drops to AP and you have to manually execute it even though it has the dashed lines.
