Making homelink work In equipped model S/X/3
So.....I purchased a US HomeLink module on eBay for my MS 90D which never had HomeLink at all (no module installed). I took it to the service center and convinced them to install it, which they did. They then had to call Tesla head office in Australia and get them to re-code the firmware to support the HomeLink module. A few days afterwards I got a firmware update message and hey presto....HomeLink appeared on my MCU. So far so good.
BUT......
I think I have made a error in choosing the module version. I should have purchased the EU version which supports 433MHz.
Our garage door opener is a GDO-9V2 Enduro which uses 433MHz.
Looking at the Merlin E8003 uses 433MHz which is not going to work with my US home link module in the Tesla.
I'll have to look online (eBay or Amazon) for the US equivalent of the E8003.
So a word of caution for those retrofitting HomeLink modules......check you get the right frequency version (US or EU).
Fantastic that you were able to convince tesla to activate that. Bad luck about the frequency issue. You should be able to buy any brand of reciever on the homelink list at the correct frequency and wire it into your door. Just watch the power voltage and power frequency when powering the reciever, US voltage is different than ours.
View attachment 356534 I got my B&D controller working today ... Thanks paulp
WZWoaji
Hi, I was wondering if you can show me a better photo of the B&D circuit board green connector with the Merlin receiver wiring. I’m trying to get mine connected, however struggling a little. Attached is a photo of my connector.
Looking online, the two connections you need are OSC and 0V. These are the two normally used for a key switch connection, which is what it thinks your merlin reciever is. Make sure you use a transformer of the correct size to power up your merlin reciever.
Cheers. I will need to buy a power supply, although I noticed that my opener has a 24v dc connector sitting free, must be for some other add-on on the B&D opener. Do you know if I can use that spare supply to hard wire straight into the +/- of the receiver?
You can if it meets the voltage and amps required for the merlin reciever. Unfortunately they are a bit vague on that. My security guy strongly recommended I use a 12v DC power supply for longevity. I didn’t question why as I had one laying around.
If you get a multimeter with fine tiped probes you should be able to measure the DC supply voltage between V+ and 0V. You have to poke it into the connector so the probes touch the metal connectors in side. I think most garage door openers supply 24VDC for accessories. I know that the Garador GDO series do.
BE CAREFUL as the garage door will have a mains 240VAC live supply!!! Do not touch any other parts of the circuit board. Only connect the wiring with the garage door powered off and disconnected!!
Check the specs on the Merlin. If I recall correctly it does support +24VDC as a power source.
In that case you need to wire as follows:
Garage Opener - > Merlin Reciever (wire colour convention, just to make things easier diagnose)
V+ -> +AC/DC (use a red wire)
0v - > -AC/DC (use a black wire)
0v - > COM Ch1 (use a white wire or green wire)
OSC -> NO Ch1 (use a blue wire or yellow wire)
Just for reference: NO = normally open on a switch, COM = common on a switch, NC = normally closed on a switch. So in a resting state COM and NC are connected, and in an activated switch COM and NO are connected.
OSC stands for Open, Stop. Close. On a garage door this is where the internal wall switch is connected as momentary push button.
SB1 and SB2 are used for Safety Beams. I'm pretty sure the two 0V connectors are the same and are the ground for power, safety beams, OSC and AUX output. So you should be able to use either/both for your wiring.
As usual, all care no responsibility on my part. Check you manuals to be sure.
Hope this helps with your install.
Marty.
Reactions: ARMARM
One minor correction on my part. On the Garador GDO series the +V terminal is only powered while the door is in motion. This means it does NOT work for the Merlin/LiftMaster receiver as there is no power when the door is idle.
I had to use an external 12VDC power supply. But I got it all working with the US Homelink module in the Tesla, a LiftMaster 860LM receiver and a LiftMaster 893MAX 3 button remote to do the HomeLink learning. The LiftMaster gear came from Amazon in the US.
Yippie!!
BUT......
May i ask how you convinced them to get it recoded?
I asked my service center the other day, and the response i got was, due to it not being standard, they cannot help.
I asked them very nicely.
Basically I turned up to the service center with the HomeLink module in my hand and asked if they would fit it. They said it was not standard practice and gave no guarantees it would work. Obviously I had to pay for the labor. They also had to re-code the car itself. I then had to wait for the firmware to be pushed out again, after they called Sydney and talked to some sort of advanced technician who has the ability to modify the firmware profile for individual cars.
They were very clear that the HomeLink module would not be covered under any warranty.
Reactions: ICUDoc
Marty.
Champion
Marty.
Hi, thanks again. I checked the voltage and unfortunately got a higher reading. Reads approx 33v. There is seperate add-on connector(refer photo), seems to be fitted for some sort of expansion. That reads 27v. Do you think I’m running the risk of exceeding the Receivers capacity and potentially burning it out?
The recievers instructions have a table addvising the minimum and maximum voltage, as well as the amps. Shouldn’t be any issues if you are within this specification.
You should be fine. According to the E8003 manual it can handle up to 34VDC:
"Power. . . . . . . . . . . . . . . . . . . . 9-30V AC or 9-34V DC, 50mA"
The expansion connector you mention is probably for a backup battery. So best not to use this. But check the manual for what it is for.
Often you will get a higher voltage reading from a power supply when it is not under load. I wouldn't be surprised if after you connect the Merlin to the opener, as described above, and measure the voltage again (across the +AC/DC and -AC/DC connectors of the Merlin) that it's closer to 24VDC.
I was at the SC again today, and asked the guys again if they could do this for me, with me willing to pay for it to be done.
The response I was kindly given, was that Homelink had advised Tesla that they didn't want the cars that didn't have Homelink originally, to be able to come in and get it set up.
So basically, I have a Homelink device (in the car, which I bought from the US) that cannot be set up over here, even though I was told that it is only a software update/coding required to have it enabled. Very disappointed, as that would have made my car complete. Oh well... If anyone finds a way to get this done, please let me know.
That's a real shame. I don't understand how it's any skin off their nose. Homelink (Gentex) have already made money when they built and sold the module. I don't think they any ongoing licence fees from Tesla.
I'm not certain but some people have mentioned the Homelink icon appearing after a major firmware update....without the need for any special coding. I doubt that it is that easy but it is possible. Have you had any major updates since the module was installed?
Sounds like a bit of a made up excuse from tesla. It makes no commercial sense for the manufacturer of homelink modules to refuse use in a market that is now open for them. Sounds more like a case of tesla hoping you will buy a new car to get homelink.
If your tesla has a homelink module, and it shows up on your screen, and if you have tried programming it but the headlights don’t flash, it means your door or gate is not compatible.
To fix this you can purchase a reciever from Merlin Australia model E8003 for just under $150. You will also need a corresponding remote E950M to program the tesla. Merlin can be contacted sydney 1800638234. If you are in a different state they will provide a supplier contact. The adelaide guy was driving past my office so delivered it to me 10minutes later. He was happy to wire it in, but its just two data cables so I did it myself.
Merlin is owned by Chamberlain who are owned by Gentrix who make Homelink.
For anyone in Adelaide the supplier is Advanced Garage Doors 0414400954.
Hi,
I know this is an old post Paul but I’m going through hell trying to get any sense out of anybody about how to get Homelink working on my BnD garage door or my ATA gate. I’ve actually got it working on the door to our underground car park in a block of units. So I know I have it and it works on some doors.
I have a 2019 MX.
However, when I pair the car to the home garage door and gate, it all goes to plan but it doesn’t work! I tried what you suggested installing a Merlin E8003 receiver but that didn’t work either. It could be that it’s not installed correctly because the installer didn’t seem to good at what he was doing.
Anyway I rang the Adelaide Advanced Doors guy and he’s pissed off because he’s getting lots of calls about it and claims not to know anything about it. I’ve contacted BnD and they are clueless. I’ve contacted Merlin/Chamberlain and they are equally clueless and not particularly interested despite Homelink being their product in America. Pls can anyone tell me someone who knows what to go? Or go I just give up. TESLA aren’t interested either. I’d buy a new motor if that would help!
Hi,
I have a 2019 MX.
A new motor wont help, and you have the right gear. Do you have a remote programmed to the merlin device? This is essential.
A remote programmed to your old door isnt suitable.
Reactions: ARMARM
If you have correctly programmed a merlin remote to the merlin reciever and it still doesnt work then its wired incorrectly. If you post a pic of your connections (or PM me and I’ll send you my email) I can the. See if the correct terminals are being used.
The merlin reciever will definately solve your problem once its all installed correctly.
Reactions: ARMARM
