Manual firmware update (for new charge port)
Discussion in 'Model S' started by janisv, Feb 4, 2019.
  1. Galve2000
    Galve2000 Member
    NYC
    is this a US spec car or euro spec?
  2. kdday
    kdday Member
    AZ
    It's probably euro, but that shouldn't matter. All of the above is region agnostic.
  3. janisv
    janisv Member
    Latvia
    Europe.
    But after plugging in city charger, then home charger works without warnings and chargee port pulses green :)
    Tesla really likes restarting, connecting
    /disconnecting, retries and whatnot.
    • Funny x 2
  4. Galve2000
    Galve2000 Member
    NYC
    the US spec charge port does not handle 3-phases.. that's why i am asking... is it Mennekes Type 2 or J1772?
  5. janisv
    janisv Member
    Latvia
  6. gde_eu
    gde_eu Member
    Europa
    For info : "Limited charging" appear when the plug is not well inserted. It still charge, but it's limited to 11 kw (Euro spec), so if you have the basic on board charger, it's also the max the charger can handle so you see no difference.
  7. Galve2000
    Galve2000 Member
    NYC
    That's european spec... very nice.. it should be charging from 3 phase normally.
  8. gde_eu
    gde_eu Member
    Europa
    He was talking about 48 km / h which is what you get with 3 phases 16 A in Europe with the standard charger (11kw) so this plug is working correctly.
  9. Username1692
    Username1692 New Member
    2545 Du Lac Trace, Seabrook, TX 77586
    Great read about problem solving. I am a frustrated 2018 Model 3 owner and wondering ... since I am not a software engineer, is this the car for me? I do not recall anywhere in my purchase agreement I was buying a vehicle in continuous beta test. I am getting tired of suffering the slings and arrows of being an early adopter. As Geoffrey Moore wrote in his book Crossing The Chasm, the most difficult step in making the transition in the technology adoption cycle is from early adopters to the majority (safely arriving well under the bell curve). Crossing this chasm from early adoption to majority is where most high tech ventures fail. If Elon wants to achieve success here on earth, he best figure out a solution for highly reliable connectivity on cloudy days, including Bluetooth, because I'd hate to be the first to file a Lemon Law suit.
  10. turbosetch
    turbosetch Member
    United States
    Just a bit more input here. I have had the same sort of issues with the factory-redeploy.
    I have found the consistent way to make it work properly is to get connected but before you issue the command use the MCU to turn the power off then run the command. The car will then turn on and off a few times make a bunch of clicking then after 20-30 mins come back up.
    If you monitor /var/log/syslog and grep for cid-updater you can watch a lot of the progress as well as know when the firmware updates have finished. You may have to reconnect a few times when the MCU reboots. You can tell the process has ended when you stop seeing messages from the cid-updater, this is the process that performs the updates.
    Sometimes after the update you have to wake the car by opening the door, you might find the MCU is blue. At this point reboot with the buttons on the steering wheel and you should be good to go. I always do this while in the car with the doors closed and you can listen and see the car doing things to indicate the process is underway.
    I also find that if you do a factory-redeploy without skipping the APE then it will almost always fail with the gateway error.
    NEVER EVER pull the power during a firmware update. As said here wait an hour or so in some cases for this all to work.
  11. brkaus
    brkaus Active Member
    Austin, TX
    Sounds like you should discuss lemon law return or buyback with Tesla.
  12. laurynas
    laurynas Member
    Lithuania
    Great topic. Thank you guys.
    I think I have similar issue. I have replaced my US radio to European one. Changed some parameters, restarted MCU and seems that radio is already working as expected, but I can still see some alerts:
    GTW_w131_tunerVersionMismatch
    GTW_w132_tunerDspVersionMismatch
    GTW_w133_tunerCalVersionMismatch
    Wondering if I can simply redeploy tuner fw only. Car is ready for new fw version, but I'm still postponing it. I'm afraid that new radio can cause some troubles. I can see that hardware is different, but are there any firmware differences? What if there are differences? Can it brick EU tuner while trying to upgrade it with US firmware?
  13. kdday
    kdday Member
    AZ
    Go ahead and install your new software. It does a deploy of all firmwares the same as a redeploy does
  14. brkaus
    Austin, TX
    So, if I want to swap out a headlamp with something from eBay... I wait on a firmware update to be staged before installing it?
  15. Uncle Paul
    Uncle Paul Active Member
    Canyon Lake,CA
    Am I alone in being simply amazed at what just happened in this thread.
    Bravo!
  16. turbosetch
    turbosetch Member
    United States
    The firmware is already on the car. When you do a deploy as described it will check to see what you have and install what you need or are configured for.
    Although I think waiting for a software update may do the same thing...its a good question and someone with more experience with this may know. You could also call your Tesla rep and ask them to create a deployment package for you then you will be prompted for the software update as normal.
  17. kdday
    kdday Member
    AZ
    Changing your car configuration will NOT work with a simple redeploy (IE if you change your headlamp type from HID to LED and then expect it to just "work").
    A redeploy only sends the existing car's configuration firmware to car components, so if you replace an existing part for the same part and just need it configured, you're good.
    Changing from one part to a different part (battery packs, headlights, motors, etc) requires far more invasive work to change the gateway configuration files. Not recommended unless you know what you're doing (which I don't).
  18. brkaus
    Austin, TX
    Thanks @kdday - I was thinking the simple case of replacing like for like. Reason for my headlight example is the eyebrow on both of my lights are fading. Still under warranty and will have fixed, but mileage racking up fast. Evaluating extended warranty at the moment and thinking about cases after warranty expires.
  19. chammerbeck
    chammerbeck Member
    Milwaukee, WI
    Great thread here. I don't have charge port issues but I was very intrigued with the whole Ethernet cable part. I bought the suggested cable off eBay. My S85 is out of warranty now. Figured it would be a wise "tool"(cable) to have on hand. Poking around a bit I have not seen too much. Is there a doc/thread with what exactly us end users can do via this port? I'm an IT guy and being able to telnet into my car really gets my curiosity going.....
  20. iamhtoo
    iamhtoo Member
    Yangon, Myanmar
    @kdday it's great that you shared information about factory-redeploy. It took me a long time asking people around to know that one. I also learned that if factory-redeploy fails, you can also try service-redeploy too. But it takes longer (perhaps enough time to put back APE cable).
    I did not know about the skipping modules part. That's really helpful. Instead of skipping part, can we give it a list of modules to deploy? What else can you share about cid updater? I would appreciate anything you know.
