cid-updater:11094: cid-updater Transferred 1042550848/1042550848 bytes
cid-updater:11105: Remote says: ic-updater:33362: pending_command for retry: install http://192.168.90.100:20564/dev/mmcblk0p1 -o 0
cid-updater:11105: Remote says: ic-updater:10916: uinotify /update_downloaded
cid-updater:10555: Remote says: ic-updater: 8508: unexpected write error on sid 32 fd 13: Connection refused (errno 111)
cid-updater:10555: Remote says: ic-updater:10741: sid 32 in onclose_free_on_OK
cid-updater:10555: Remote says: ic-updater:10756: sid 32 has valid esc
cid-updater:10555: Remote says: ic-updater:10758: sid 32 http client termination code -1
cid-updater:10555: Remote says: ic-updater:10760: Retrying with session->pending_command get http://localhost:4070/update_downloaded -o 0
cid-updater:10555: Remote says: ic-updater: 5322: FOO RETRY: /update_downloaded: SOCK_STREAM parent: 29 fd:13 addr:127.0.0.1:51048 dtx:4189 rx:0 tx:0 px:0/0 inb:0 outb:128 READY:ox pending: get http://localhost:4070/update_downloaded -o 0
cid-updater:10555: Remote says: ic-updater:32601: do_HTTP_GET offset=0 download_retries=0 check_signature=0 reporting_name=doget argv_localpath=http://localhost:4070/update_downloaded
cid-updater:10555: Remote says: ic-updater:32253: HTTP Client sid 34 using session->xfer_filename = http://localhost:4070/update_downloaded
cid-updater:10555: Remote says: ic-updater: 8508: unexpected write error on sid 34 fd 15: Connection refused (errno 111)
cid-updater:10555: Remote says: ic-updater:13086: handle_http_client_completion sid=34 session_name=doget session_termination_code=-1 esc.valid=1 success_required=1 xfer_filename=http://localhost:4070/update_downloaded
cid-updater:10555: Remote says: ic-updater:13091: sid 34 http client termination code -1
cid-updater:10555: Remote says: ic-updater:13104: handle_http_client_completion status=giving_up session->esc.retries=0
cid-updater:30922: relay status=flushed monitor_sid=291 monitor_name=parse_commands filename=/dev/mmcblk0p1
cid-updater:12890: handshake_file_looks_sane status=warning reason=no_download_url
cid-updater: 5322: PREINSTALL_CLEAN: parse_commands: SOCK_STREAM parent: 0 fd:13 addr:192.168.90.100:25956 dtx:4172 rx:17 tx:183 px:0/1042550848 inb:0 outb:52 LC:serve READY:i
cid-updater:10916: uiwarn /update_spool_folder_created
cid-updater:10836: Writing sentinel handshake: host=firmware.vn.teslamotors.com port=4567 path=
cid-updater:10867: Wrote sentinel handshake.
cid-updater: 4877: can't open /var/spool/cid-updater/force_gostaged: No such file or directory
cid-updater:37391: redeploy_signature status=staging
cid-updater:22865: install status=redeploy
cid-updater: 4607: updater_system status=starting cmd=/usr/bin/curl --max-time 15 http://localhost:4035/firmware_bandwidth --data-ascii '{"bytes":223}' timeout=0
cid-updater: 4507: updater_system_child status=starting arg=F /usr/bin/curl --max-time 15 http://localhost:4035/firmware_bandwidth --data-ascii '{"bytes":223}'
cid-updater: 4639: updater_system status=clone_started pid=980
cid-updater: 4651: updater_system status=child_returned pid=980, rc=0
cid-updater: 4657: updater_system status=child_exited rc=0
cid-updater: 5322: TIMER: do after: timerfd OD parent: 0 fd:18 dtr:-1 READY:i pending: stage
cid-updater:34090: verify_offline_and_stage sid=475 retry command=
cid-updater:34844: sid 475 has just asked to be kept awake
cid-updater:34138: signature status=starting
cid-updater:12004: send_gwcmd line=12229 sid=475 status=success latency=0.10 command=0xa retval=0a01
cid-updater:12662: verifysig status=in_progress fused=1
cid-updater:32253: HTTP Client sid 479 using session->xfer_filename = /var/spool/cid-updater/dv-VAPI_isEbuck-response-475.part-475
cid-updater:27095: is_ebuck rc=0 result=false
cid-updater:32253: HTTP Client sid 483 using session->xfer_filename = /var/spool/cid-updater/dv-CD_displayState-response-475.part-475
va.teslamotors.com/492d2665fa330fed2be90d5c089c9cd9?_gda_=exp=1598247896~acl=/492d2665fa330fed2be90d5c089c9cd9~data=43331775~hmac=3a2937365a596023466cc5f75c707ba0d2d70fdf210e1122bd66400cc2ca28bb
cid-updater:32167: request_HTTP status=failure activity=download reason=connect_failed host=va.teslamotors.com port=80 path=/492d2665fa330fed2be90d5c089c9cd9?_gda_=exp=1598247896~acl=/492d2665fa330fed2be90d5c089c9cd9~data=43331775~hmac=3a2937365a596023466cc5f75c707ba0d2d70fdf210e1122bd66400cc2ca28bb
cid-updater:35609: download status=retry reason=DNS_resolution_failure
Will this also trigger a firmware download if the car has no updates to do?Not too hard really. You need an Ethernet to Fakra 4 pin hsd cable. Then you'll need to plug into the car network and redeploy your firmware so that it upgrades the firmware on your new charge port.
Buy this
Tesla Service Cable Ethernet FakraHSD for Toolbox 1.5ft Model S/X | eBay
Then once you have it, remove the glove box and look at your APE computer behind it. Remove it's white Ethernet cable and connect your new cable to it (this is the Ethernet cable going to your MCU).
Then, plug the Ethernet cable into your laptop and set your laptop ip address on the Ethernet port to 192.168.90.103
Then use a terminal to telnet into your MCU by typing "telnet 192.168.90.100 25956"
Then type "factory-redeploy" and hit enter. Your MCU will turn blue after a few seconds and start the automatic firmware redeploy to all car components. You do NOT need to push any buttons on the MCU to start it. Just wait. It'll reboot a bunch. 45 minutes later it'll be complete and say so, but still be blue.
Restart the MCU by holding down the two steering scroll wheels for a few seconds in order to make the blue screen go away.
You should be done.
not reallyWill this also trigger a firmware download if the car has no updates to do?
if not what command would trigger a firmware download?
Is there a way to request the latest firmware update or can only Tesla do that?not really
depending on what version your car right now
reset updater and handshakeIs there a way to request the latest firmware update or can only Tesla do that?
