Manually warm up battery?
Discussion in 'Model 3: Battery & Charging' started by Sam1, Jan 3, 2020.
  1. pt19713
    pt19713 Member
    Delaware
    #21 pt19713, Feb 11, 2021
    At a V3, I was able to get the packs to 131F/55C.
    Ambient temps were 33F/0.5C.
    Pre-conditioning in the garage at home, the front motor doesn't appear to go above 210F but at the SC, I've gotten it to 252F/122C
  2. Sam1
    Sam1 Member
    NV
    130 is where active cooling kicks on, so unless you're running the car hard on the track or like here in Vegas when it's 119 degrees in August, they rarely stay above 130 long at all.
  3. jim0266
    jim0266 Member
    Ohio
    To add more evidence to this reply...
    2019 Model 3 LR (w/o heat pump) battery conditioning test. The goal of the test was to see how turning on the HVAC only to preheat the cabin effected the battery temperatures in a cold climate. The car was plugged into L2 during this test and the HVAC only is started. Charging does not start until noted below.
    All the stats below were gathered from ScanMyTesla. SMT reports both a SOC and a SOC Expected value. The SOC Expected number falls below the SOC number when the pack is below around 68°F. The SOC expected value is what’s shown on the cars screen and used to calculate expected range. This value is also used by apps like Stats to calculate range and battery degradation. I have photos from another test showing this at the ScanMyTesla post.
    Temps were in the lower to mid 20’s for several days. Car not driven or plugged in for those days before start of test. Car was stored in an unheated garage.
    The stats
    Start cabin heating at 10:47
    Min 37.4 °F
    Max 38.3 °F
    Avg 37.9 °F
    SOC 42.1
    SOC Expected 37.5
    10 mins 10:57 (3 degree increase)
    Min 41 °F
    Max 41 °F
    Avg 41 °F
    SOC 41.9
    SOC Expected 37.5
    20 mins 11:07 (9.9 degree increase)
    Min 47.3 °F
    Max 48.2 °F
    Avg 47.8 °F
    SOC 41
    SOC Expected 39.9
    30 mins 11:17 (17.1 degree increase)
    Min 54.5 °F
    Max 55.4 °F
    Avg 55 °F
    SOC 40.8
    SOC Expected 39.9
    40 mins 11:27 (24.7 degree increase)
    Min 62.6 °F
    Max 62.6 °F
    Avg 62.6 °F
    SOC 40.8
    SOC Expected 40.4
    50 mins 11:37 (29.2 degree increase)
    Min 66.2 °F
    Max 67.1 °F
    Avg 66.7 °F
    SOC 40.9
    SOC Expected 40.4
    —L2 charging Started—
    2 hours hours after start of preconditioning and 1 hour of charging
    Min 70.7 °F
    Max 70.7 °F
    Avg 70.7 °F
    SOC 50.1
    SOC Expected 49.9
    3 hours later. End of charging at 60%
    Min 73.4 °F
    Max 74.3 °F
    Avg 73.9 °F
    SOC 59.9
    SOC Expected 59.8
    • Informative x 2
  4. Brock-WI
    Brock-WI Member
    Green Bay, WI
    Jim I am confused, did you open the door and physical start the HVAC and left the door cracked?
    I also have Scan My Tesla and actually did a similar thing this am. I think the difference may be I have a 2018 SR (single motor). All I did was tell the car to start charging, never opening the car. The pack started at 28F. SMT was showing it charging the pack with 3.5kW and the rear (only) stator running consuming 3.5kW as well. After about 1 hours the pack was up to 49F and that is when the rear stator stopped running / heating the pack and then the pack started charging at 7.5~8kW. Really what I was testing for was if the car warms the pack for just AC charging and it does. I assume it does the same thing when you set a "depart time" backing up and guessing how long it needs to warm the battery and charge it to the set point, but it seems to get the pack to about 50F.
  5. GtiMart
    GtiMart Member
    Quebec City, Canada
    The car will heat the battery to around 10C when AC charging. It will go higher, to around 20C, when preheating before a drive.
  6. designrs
    designrs Member
    Jacksonville, FL
    I’d worry more about warming up the tires before pushing it that hard. (Not burnouts, but just normal driving.) These “opportunities” of ambition often occur shortly after leaving a parking lot with cold tires. Unfortunately, many great cars have been damaged even with advanced traction control.
  7. jim0266
    jim0266 Member
    Ohio
    Hi Brock, I have a LR RWD. I did not open the car door. I started the HVAC from the app.
    Thanks, what you did was my next test. I was wondering if the car would start charging immediately if the pack was at low temps or first warm the pack and then start charging. Interesting to note that 49F is the point charging starts. Your question about depart time is one that I wonder about too when it comes to preheating the battery and adjusting the time needed.
    I did find this at https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=48711&flag=1
    "If the battery temperature is near or below freezing temperatures, normal charging will not occur. The vehicle will identify this condition and will begin heating the battery coolant and circulating the coolant to raise the battery temperature to enable charge. When the pack temperature rises to a temperature within the allowable charging range, heating will reduce or stop and charging will commence."
  8. SigNC
    SigNC Active Member
    NC
    #28 SigNC, Feb 14, 2021
    lots of misinformation in this thread and I wish tesla would at least document what is happening for people that want to know the complexity. From what I can tell if you turn on cabin heat (remotely, not in the car) and the battery is below around 50f it will heat the battery up to about that point. So, you will get in and there will be a little bit of regen limitation but certainly nothing like if you didn't preheat. As soon as you get in the car, the preheating of the battery turns off. If you set your car to maintain climate, when you get out if the battery is below the ~50f it will again start warming it as long as you are no longer in the car. The key is climate on, nobody in the car for the battery heaters/motor heat (or as bjorn calls it, afterburners) to be running. You can easily see if this is happening by looking in the app under climate and seeing the red battery icon. Being able to see this in the app was added maybe....2 months or so ago. It's also nice to know that if you leave your car preheating with a very cold battery and you don't need regen or plan to fast charge, you are likely heating up your battery to 50f for basically no reason. I usually just do a 5min or so cabin preheat and hit the road unless I'm planning on going to a supercharger.
    TL;dr if you turn on climate remotely and your battery is below 50f it will warm the battery.
    P.S.- This information is ESPECIALLY helpful if you've left your car outside in very cold climate and plan on supercharging soon after your departure. Let the car get the battery up to 50f before you leave, then put SC in the navigation when you leave so it further heats on your way.
  9. jrweiss98020
    jrweiss98020 Tessa's Tesla
    Edmonds, WA
    How do you know what your battery temp is?
  10. Brock-WI
    Brock-WI Member
    Green Bay, WI
    So I saw the pack temp at 28F and it was charging the pack at 3.5kW. I wonder at what pack temp it will heat up the pack up before charging from AC at all. According to that article it was below freezing, which my pack was, but still charging at 3.5kW. Maybe I was right at that limit?
    My other question is if say you leave the car plugged in overnight on 120vac outside at -10F or -23C with no departure, at what temp will it wake up and start warming the pack? In other words how cold will the pack get if left on its own plugged in vs on its own battery.
  11. GtiMart
    GtiMart Member
    Quebec City, Canada
    Using ScanMyTesla.
  12. user212_nr
    user212_nr Active Member
    US
    Set the car's acceleration to "Insane+" and it will heat the battery, in addition to preconditioning. I'd guess you might already be on this mode, so maybe temp is not the problem.
    You are correct at the loss of power correlating with the battery percent lower. Max power = current x voltage. The max current is the same so as battery voltage drops so does the max power (simplified version). Charging to 100% will give you the fastest times.
    • Disagree x 1
  13. Gasaraki
    Gasaraki Active Member
    Syracuse, NY
    This the Model 3 forum.
