Norbert
TSLA will win
Probably. Please target Norbert if you are so inclined, he's closer to you, fewer emissions from travel.
But it would be using unsustainable energy.
That's extraction and refining. What about transportation to your local station (varies, I'm sure, but not everybody has a refinery in their local area)? And how about transportation from the extraction point to the refining point? I imagine some big losses could come from those, and I also imagine those numbers are included in the efficiency percentages for electricity.Extraction for conventional petroleum extraction is 92% efficient, Alberta oil sands 82-86% efficient, http://fossil.energy.gov/programs/reserves/npr/Energy_Efficiency_Fact_Sheet.pdf
refining 90% efficient,
http://www.transportation.anl.gov/pdfs/TA/635.PDF
Notable is the loss of efficiency projected for the future of extraction.
But if the transportation costs aren't included for electricity either then I suppose it is a fair comparison.
I've figured out what bothers me most about these figures: 33kwh equivalent per gallon.10 gallons of gas at 33kwh equivalent per gallon is 330kwh. The entire petroleum chain from well to tank is about 80% efficient, so that means 20% is used to produce the final product, so the 10 gallons took 66kwh of energy, (not electricity). Now don't forget that the 85kwh's of electricity in a battery pack started out as a lot more energy than that using a generous 40% generating efficiency, (marginal power is probably lower), plus 93% transmission efficiency, a generous 90% charging efficiency, and not to mention the drilling/mining energy inputs, which I don't have the figures for. You have to apply equal criteria for all inputs when comparing gas to electricity.
How did that number get figured? I know of no way to convert 1 gallon of gasoline to 33kwh of electricity. There are enormous losses involved in any conversion of gasoline to electricity so the number must be something like the amount of work a gallon of gas can do ... like power a car. If that's the way the equivalency is developed then no wonder all the math ends up with them equivalent. You come up with a more efficient car than the average car the equivalency was developed on and bingo, the more efficient car is more efficient.
