stopcrazypp
That is not exactly correct. For the most part nuclear never ramps down, yes some hydro does get backed up, for daytime use. Coal and NG do ramp down, but they don't produce unused electricity, what they produce is used. If there is more night time demand then they won't ramp down as far. Glenn is essentially correct that marginal load at this point is met with coal or NG.
I think that way of looking at things is completely BS and is essentially just a very contrived way to assign the worse plants to EVs. What you really care about is the amount of CO2 emitted during the period your EV is charging. That means when you calculate emissions, what you have to look at is the average CO2/kWh emitted by your utility during your charging session and then adjust that by the amount of kWh you used. To be extremely accurate, if you have an instantenous graph of CO2/kWh during the day for your utility, and the kW profile that your charger draws, then you can calculate how much CO2 can be attributed to your charging session. All the talk about baseload and peaking is a just a proxy way (that may or may not be accurate) of trying to figure out this number.
This electricity demand is shared equally among ALL your appliances and ALL the households powered by your utility. Unless the utility has a direct connection to your EV charger, it's not responding to your EV specifically, it's responding to the entire load as a whole. It doesn't make any sense to only assign the coal/NG plants to EVs and then the rest of the cleaner ones to non-EVs.
For example, if you run your heater at the same time that you charge your EV, why should the EV be assigned as the "marginal load" and the heater not. If the only thing running in your house is your EV charger, then why should YOUR household be the only one assigned as a "marginal load" and not other households that may be running other appliances. What's so special about EVs chargers that they HAVE to be the "marginal load" no matter what (and 100% at that), and why do we ignore all other appliances?
