Your post that I quoted stated that CA does not use coal. Also, you were the one who brought up solar input, when it has no relevance to the marginal load discussion. Maybe it's just me but you aren't making much sense at this point.
Coal is used in CA both day and night, but not ramped up or down when the load on the grid changes, or to be exact, not in a way that one would notice in the numbers.
There are three conclusions I draw from the study (assuming that it is correct, it seems well-researched). These are somewhat independent of each other, but all result from examining "marginal emissions", meaning, emissions resulting from the effects of adding additional load, at a specific point. (Which implies blaming EVs for things they are not really responsible for.)
1. The time at which charging an EV causes the least amount of additional CO2, is between 2 am and 4 am (California average). (Regardless of other reasons to charge at night.)
2. Any EV charging at that time will apparently produce less additional CO2 than a Prius. (And EVs charging at other times not really that much more than that). The CO2 values at ~3am are, I think, good even for NG, and better than grid overall average (at least around 2007).
3. Examining which power plants are being ramped up and down during the day, also shows that solar peaks at a time at which marginal emissions are higher that usual, so solar has a higher benefit in reducing CO2 than it would have if it peaked at some other time. (Which has nothing directly to do with EVs, except that having an EV might motivate you to buy solar, and that both support for EVs, and support for solar, are results of a pro-environmental development in general).
