Mars and Off Planet Colonization
Discussion in 'SpaceX' started by claytorj, Nov 26, 2013.
Tags:
  1. mongo
    mongo Well-Known Member
    Michigan
    Thanks, that explains where the reaction gets its hydrogen from, but makes me ask: "Where did they find enough potassium bicarbonate on Mars?", not that there haven't been traces detected : Vastitas Borealis - Wikipedia
    C is from the Martian CO2 atmosphere.
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    Use a translator. That will convert Mars to March and you have both C and H.
    More seriously, although Mars' atmoshere is only 1% of Earth's, it is 95% CO2.
    Apparently the answer to the energy needs is to bring potassium.
  3. ItsNotAboutTheMoney
    Maine
    Although ...
    Martian soil - Wikipedia
  4. AudubonB
    AudubonB One can NOT induce accuracy with precision!
    #344 AudubonB, Mar 4, 2021 at 4:25 PM
    A small number of posts in the Investor quagmire regarding the eventual forging on Mars of semiconductor chips prompted my thinking of raw materials necessary to an extraterrestrial colony. Many of these have been discussed or at least alluded to either in this thread, elsewhere within TMC, in popular media and amongst specialized Martian publications.
    The latter I have not good access to, and perhaps the following topic has been addressed there. Happy to learn if someone knows any other discussion re same.
    Easy ones to consider, if not to solve for: water, oxygen, energy, iron, silicon, steelmaking alloys like Ni, Cr, Co and others. Battery raw materials like Li, Ni (again). Soilmaking enrichers like Ca, K, P, N. Saline anodes like Cl. Monster anodes like F.
    My concern is with another element, one ubiquitous not only in humans' daily lives but omnipresent also in all phases of the transportation sector - aluminum. Now, Al (that's not AI but Al. Do you see the difference? No, neither do I. First abbreviation is for Artificial Intelligence and the second is for element #13, Aluminum/Aluminium). Al is indeed well-thought to be approximately as common in Martian crustal material as it is on Earth - about 5th in abundance after Si, O, Fe, Mg. The BUT is, however, extraordinarily large and troublesome.
    Exactly 100% of all primary aluminum mined on the earth comes exclusively from deposits formed in just one way: the extreme action of rainfall over not millions, but many tens or hundreds of millions of years. Once aeons of rainwater have leached out everything else: all the other rockforming elements like magnesium, sodium, and even silicon (did you think quartz - SiO2 - is hard and weatherproof? Not by geologic time standards it isn't), and even the removal of that second-most resistant material - iron oxide - that which is left over is aluminum oxide (bauxite & ilk). There is NO other source* of aluminum.
    And, unless the former Martian water processes now quiescent for X*10^9 years had been strong enough and prolonged enough to have acted similarly, then aluminum will not be available on Mars.
    Why not, you ask, if the energy problem can be solved and the element is indeed present in Martian crust? Because rockforming mineral that contain aluminum - feldspars and so forth - divulge their elemental metal even more reluctantly than that so-called hardest of all metallic nuts to crack - aluminum oxide (bauxite). Aluminum so derived is called 'canned electricity' for good reason. Attempting to concentrate Al-poor sources into pure feldspars, and then releasing that metallic Al, would be many times more energy consumptive.
    A way to put historical perspective on this: prior to the development of the Hall-Herout method of electrosmelting of bauxite, Aluminum metal was so rare that it was more precious than gold, and Queen Victoria was gifted an incalculably valuable aluminum service as a gift (now retailing at Wal-Mart for $27.99........).
    So. What to do? Three answers from me.
    1. Refer back to the propreantepenultimate paragraph's *asterisk. For a short number of decades, there was ONE other source of aluminum; one not a function of weathering but rather, from 'pure' magmatic action. A rare mineral in pegmatites - that final exhalation from a cooling magmatic chamber, and one in which all the hard-to-incorporate into "regular" rock-forming minerals (boron, beryllium, lithium, uranides and so forth) - is a sodium-aluminum fluoride called cryolite. It has been found in minute quantities in a small number of pegmatites in Colorado, Russia and China....and in exactly one single location in coastal southern Greenland where it was a large enough deposit to be mined from the 1860s until exhaustion after WWII.
    There is no reason at present to believe that magmatic intrusions like pegmatites might not once have occurred on Mars. Those in which cryolite has been found seem to share gneisses as their matrix - some gneiss is highly feldspathic and possibly the pneumatolytic fluids associated with the proto-pegmatite leached Al, to be grabbed by that most vellicate of elements, F, to create cryolite. A concerted search for pegmatites peripheral to, for example, Elysium Mons or Hecates Tholus rather than that most familiar gargantuan Olympus Mons, as the latter is too similar to Earth's shield volcanoes to be a likely former of pegmatites. But areology remains hardly even in its infancy and it is risible to consider a keyboardist's ramblings as an authoritative guide to mineralogic exploration.
    2. Consider Earth as the source for Al and calculate the costs of importing either ingots or pre-created alloys for.....¿perpetuity?
    3. Embrace the lowered gravity of Mars and substitute iron and steel for items that on Earth would be made from aluminum.
    Cost-Benefit analyses await....
    • Informative x 6
    • Love x 2
  5. Oil4AsphaultOnly
    Oil4AsphaultOnly Supporting Member
    Arcadia, CA
    Al is easily recyclable. Given it's high conductivity, electric arc furnaces that turn parts of the cargo containers (I'm assuming that cargo containers would be needed to keep stuff from jostling around during launch and landing) inside the starship into new products would probably be the lightest (the crucible doesn't have to be very large) and easiest industry to startup. That would be the short-term solution for any Al supply issues.
    And yes, substituting iron and steel for bulk structures would be next longer term solution. Without water vapor in the air to promote oxidation, iron oxide might not be as prevalent of a problem on mars as it would be on earth.
  6. AudubonB
    #346 AudubonB, Mar 4, 2021 at 7:08 PM
    Re-using aluminum is indeed utterly essential; my thoughts were that the amount arriving as the interplanetary analogue of conex containers would be minuscule - that more mass-efficient methods of cargo handling will be used. I have, however, been envisioning the Transformer-like organization of items like terran-made Martian vehicular aluminum chassis themselves being also the means by which other material is secured.
    More: in that I don't Moderate this section I haven't unlimited "Edit" ability. Two sentences in the ending portion of post #344 would be both more grammatical and more understandable were they changed by adding the italicized parts below as follows:
    1. The sentence beginning "A rare mineral in pegmatites..." should have its center changed to "...all the elements hard to incorporate into....uranides) are concentrated - is a..."
    2. "....Olympus Mons...too similar...to be a former of pegmatites might prove fruitful".
  7. Oil4AsphaultOnly
    Arcadia, CA
    That would indeed be more mass efficient, but only for the outer container. It's a 7-month trip, consumables will occupy a significant amount of the actual cargo volume. Even accounting for dehydration, you'd need about 460 lbs of dehydrated food (1-Year Emergency Food Supply (2,000+ calories/day)), occupying ~30 cubic feet of space. Not including water (which would be recycled). Using aluminium "tins" instead of plastic bags would mean less "trash" on mars. Plus the pre-supply ship would have the same amount of food-stuffs packaging (if not more).
    Unless, they're relying on hydroponics to reduce the food requirement?
  8. LiveLong&Profit
    Earth/EU/DK
    Even the most optimistic scenarios would have Mars and other off-world habitats being utterly dependent on earth for many decades, perhaps hundreds of years.
    Given that, establishing a large scale import/export infrastructure makes good sense.
    A key component would be a mass driver on the moon. The moon is delightedly close to earth so getting manpower and material assets to both mine what materials can be gotten from the moon and forward other stuff (raw materials, chips, luxury food, etc) seems a logical necessity. Combine that with a cohort of freighter/carriers cycling Mars orbit solely for intercepting mass-driver shipped goods from the moon and getting that to Mars proper.
    What will Mars export back? The first couple of years: People. And perhaps Mars rocks for sale on earth, until the novelty (quickly) wears off.
    Over time, any self-respecting Mars colony will also do Mars and nearby asteroid mining. Given that the reusable spaceships have to head back to earth, due to cost/economy of the colonization effort, there might be room for a few tons of stuff on the return trip. Yes, Elon has joked that even crack cocaine would not be valuable enough to import from Mars. But, that assumes 'normal' shipping logic. If the star ships absolutely have to get back to earth no matter occupancy rates, then there might be some possibilities there. Of course the extra fuel spend per weight unit is a huge problem.
    But, it really depend on the cost of local energy production on Mars. Given a high enough industrial base, local production and deployment of solar arrays at a huge scale (likely over decades) and perhaps some micro atomic reactors as well the cost local energy comes down gradually.
    It makes sense for the moon mass driver array to also be utilized for transport towards earth and combined with orbiting earth freighter/carriers for intercepting goods and doing 'last mile' transport that would bring down the cost of 'shipping' stuff back from Mars and the off-world colonies down a lot, thus closing the import/export loop and thus making the whole infrastructure that much more reasonable at a massive scale.
  9. AudubonB
    Just as a clarification - not that it was written in the above post - but aluminum itself will not be available for extraction either on the moon or in asteroids. I’ve not given any thought to Venusian-derived Al, other than ceteris paribus, why bother? I’ve heard it’s available on Earth.
  10. winfield100
    winfield100 Supporting Member
    vivant non-traveler
  11. AudubonB
    Those lunar soil data present exactly my case: elemental aluminum is omnipresent.
    All you have to do to obtain it on the moon, or on Mars, or on the island of Hawaii.....is to take that ubiquitous plagioclase feldspar-containing rock, subject it to 200-300 million years of tropical rain, and ta da! you have high-quality bauxite, ready to be electrozapped to free its metallic soul.
  12. AudubonB
    I have, however, been re-thinking it overnight. It is not impossible that there is another way - one which also takes natural forces to make them do the heavy lifting - which could, maybe, possibly allow us to find on Mars high-grade aluminum ore, ready for smelting.
    More later, but I’ve provided clues in the first paragraph.
  13. Oil4AsphaultOnly
    Arcadia, CA
    Mars has less solar irradiation than earth, so any electricity derived from photovoltaics would be too valuable to squander on any kind of heavy industry like refining metals on mars. So I think importing refined aluminium produced from the moon would be a permanent solution. A mass driver delivery system on the moon would be most energy efficient and free from the limitations of transport intervals. Metals and rock from nearby asteroids should probably get delivered to the moon base for refining and delivery to mars.
    Without an atmosphere, concentrated-solar-thermal foundries should be viable on the moon. There's a CST furnace in France that's already demonstrated this to be possible. How to run a foundry in a micro-gravity might be a tough engineering problem to solve though.
