Yes I'm running in SS. Had the tire pressures around 40psi hot. Think I will try a bit lower pressure at next event. Still waiting for my Eibach rear sway bar to arrive.
Tony-
I may have missed something you said earlier, but is there a reason why you're looking only at Michelins? (or am I wrong with that assumption?)
Makes no sense that the A/S 3+ would be worse than the MXM4Most major on-line tire companies like Tire Rack, Discount tire, etc. allow you to set up a comparison chart among up to 3 alternatives, but they don't include rolling resistance. During a chat with Michelin, they were able to quantify "Fuel Efficiency", so I used their data to make the following table for the Michelin tires under consideration. Unfortunately, all four have a Fuel Efficiency" of 9 and there is only one significant digit. Somewhere in this thread (cdrikari?), the cross climate, which BTW has the best Average Score, was said to have more rolling resistance than the MXM4. So I think we know more about Michelin Tire performance than they do!View attachment 568435
Why are the MXM4 so expensive?
Can't see the attachmentReplaced by 20” wheels with MW03 19” wheels. I’ve got a few miles on them now and it’s a definite improvement over the factory wheels. The ride a noticeably better.
Works on 3/YAnybody know of a discount code that's still active? Also, did you guys go with the sensors from martian or go with something else?
Works on 3/Y
https://www.amazon.com/dp/B07CTB7WM8
Ordered these for around $73
They have worked fine for me and its my second set of them. The stem is silver but they do make a black one just more expensive.
FYI....The TPMS sensors for the M3 are not compatible with the MY. The TPMS sensors for the MY are now bluetooth and, at this point, are only available directly from Tesla for $75 each.
