Atraf
Thats awesome, hows your experience in terms of driving comfort? traction/grip?I have 225/50R18 tires on the 18x7.5 MW03 wheels and they work fine.
Any chance for couple of pictures?
This looks so good, how much clearance do you have to the Upper Knuckle in the front?More pictures to show how the wheel and tire is in relation to the body of the car 18x7.5 on 225
My first order was 5.5 weeks. My second order is about a week out per Drew which is 7 weeks for the second one which I assume is due to everything slowing down.How long did it take you all to get your MW03’s after you ordered?
Looked up the MXM4s and they list rim range of 7.5 to 9 measured on a 8". This would be on the lowest end which means the tire would be slightly more bulged out relative to the rim. But yes you can reuse them.could I use the stock 235-45-18 tires on a 18-7.5 wheel mw03.
Thanks for finding that for me. Looking at mw03 rims. I want a little bulge to protect new rims. Stock rims on my 2019 stealth are wider than the tire. W hen I pulled the rims to paint the calipers the rims touched the floor before the tires. Will go with different tires when these wear out (7000 Happy miles!)Looked up the MXM4s and they list rim range of 7.5 to 9 measured on a 8". This would be on the lowest end which means the tire would be slightly more bulged out relative to the rim. But yes you can reuse them.
Why do you want to limit yourself so much with a rim 1" narrower than stock?could I use the stock 235-45-18 tires on a 18-7.5 wheel mw03.
I believe I still have an active one for at least one more use.The $200 discount code expired April 20, when I just squeaked in my order for 18"x8.5" silver and the outlook was 2 weeks. Their shipping seems reasonable too at $100 for a set of 4.
Wow, must have been a huge pothole. There are services that can repair bent wheels for ~$100, but that one looks cracked and may be too far gone. Amazing that it still holds pressure... you must notice some vibration. This vulnerability, along with weight, is why I ordered forged 18" Martian wheels for my just-delivered M3P.Just missed the boat on these with DT’s code. Actually kinda need them now due to the junk build on the stock boat anchors. I’ve never had a road gator (retread castoffs from semi) bend a wheel before but I suppose there’s a first for everything. Tire seems okay other than a nick and is still holding pressure.
Yeah: It’s cracked bad but somehow holding all 45psi cold just fine. No vibrations but alignment is off.Wow, must have been a huge pothole. There are services that can repair bent wheels for ~$100, but that one looks cracked and may be too far gone. Amazing that it still holds pressure... you must notice some vibration. This vulnerability, along with weight, is why I ordered forged 18" Martian wheels for my just-delivered M3P.
