Martian wheels
Discussion in 'Model Y' started by Jmeitz, Aug 22, 2020.
  1. Jmeitz
    Jmeitz Member
    St Louis
    Just installed my 19” Martian wheels with continental tires. Much lighter than the 21”.
    91316CDF-1A5C-4EB0-97AE-F0691A473E40.jpeg CA415C73-2214-4B44-9594-B84ACA602182.jpeg 2138BFB8-CFCC-4FE6-9587-AAC86FAC3FE1.jpeg
    • Like x 8
  2. heyou
    heyou Member
    Livermore
    Looks great.
    Mine are out for delivery today.
    I have the bridgestone quiettracks on the way too so they will be mounted soon.
  3. shokunin
    shokunin P85 & M3
    Irvine, CA
    Looks great! Any improvement in efficiency compared to the Uberturbines?
  4. Wennfred
    Wennfred Supporting Member
    San Diego
  5. kpinthebay
    kpinthebay Member
    San Francisco Bay Area/Kaka'ako
    I think you have to get the SC to set it. I had to when I swapped to 21"
  6. Jmeitz
    Jmeitz Member
    St Louis
    They told me not to worry about it as it didn’t matter.
  7. Jmeitz
    Jmeitz Member
    St Louis
    No idea as I only have a few hundred miles on the Y. Don’t drive it that much.
  8. raggedy
    raggedy Member
    Peninsula CA
    looks great! I love the Martian wheel for the MY. You dropped over 10lbs on the wheel alone at each corner. This will improve the ride, handling and efficiency. Between the 10+lbs on the wheel and the weight saving on the tire, you should feel a difference. congrats!
  9. Kuro Houou
    Kuro Houou Member
    I am really curious how these aftermarket wheels do efficiency wise. Some reports show the 21" wheels while heavy are extremely efficient (Aero Dynamic) making them just as good as 19" or 20" aftermarket wheels that have poor aero. Its made me double think if I will replace them or not, if I do, they would have to be some efficient design, like the 20" factory wheels maybe (or 3rd party equivalent)
  10. zedtava
    zedtava Member
    Portland
    Tesla service told you to not worry about it? There has to be some sort of difference between Ubers and the Martian Wheels. Does the car auto correct?
    Installed my 19s today. They are very light, and I like the look. Put on some performance all season tires. IMG_4739.jpg
    • Like x 6
  11. Jmeitz
    Jmeitz Member
    St Louis
    They told me since they are the same circumference it didn’t matter.
  12. Jmeitz
    Jmeitz Member
    St Louis
    Thanks, I know it’s 20lbs or so lighter per wheel per their Website.
  13. Matsayz
    Matsayz Active Member
    Las Vegas
    To set your wheels... Hit the car settings icon>Service>Wheel Configuration
    BUT that seems to be only on my Model 3. Our Model Y doesn't seem to have the wheel configuration button at least on version 2020.28.6... I'll let you know if that changes when I install 32.3 on the Model Y
  14. acarney
    acarney Active Member
    Richland, WA
    I don’t understand, this is the second performance car I’ve seen switch from 21s down to 19s. The overall diameter should be the same (just more tire and less wheel) but the vehicles look drastically lower. Could you measure the ground clearance with that? It looks almost less than a standard Model 3. I was hoping to switch to the Y to gain AWD over my 3 and a smidge better ground clearance for winter snow... but a Performance actually looks like I might have LESS ground clearance than the ~5 inch with the 3...
  15. zedtava
    zedtava Member
    Portland
    But the range estimate will be off? I guess it may matter to some and not to others. I am curious whether they are as efficient as the 19s w aero covers, or without.
  16. Barrygold
    Barrygold Member
    Midwest
    I swapped out 21s for 20s and Tesla virtual service pushed the software change to my car. Gives me 315 rated miles at 100% SoC now. I have no idea if they are more efficient wheels than the 21s. They sure are lighter though. 26F8E2BE-5B31-4501-B384-427BEB069212.jpeg 32696E99-4120-47F2-90DB-EE7A2F9CD219.jpeg FC854B55-7F7A-4C26-9A04-D66701DF5418.jpeg
  17. Jmeitz
    Jmeitz Member
    St Louis
    I typically use the % remaining vs mileage.
  18. zedtava
    zedtava Member
    Portland
    I think I will ask service for 20 over 19s. I hear that they will ask to see new wheels.
  19. Jmeitz
    Jmeitz Member
    St Louis
    Remember you don’t gain more miles. It’s just an estimate number. The car adjust as you drive. That’s why I use % as that the only accurate number.
  20. jb401
    jb401 Member
    Chicago, IL
    Tire circumference should be identical, so no need to change settings.
