Martian wheels
Discussion in 'Model Y' started by Jmeitz, Aug 22, 2020.
  1. Ldub22
    Ldub22 Member
    Kirkland, WA
    Don't have my Y yet, but I have had 2 different sets of aftermarket wheels for my 2015 Model S, and it was never a problem getting the TPMS from Discount Tire to work with them. Just call a tire shop and tell them what you have. If they don't know, then they are bad at their jobs. It's not like Teslas are rare anymore!
    • Disagree x 2
  2. Ldub22
    Ldub22 Member
    Kirkland, WA
    I have never had any problem with Discount Tire TPMSs for my 2015 Model S. I know it is a different car, but same software. If the tire shop can't help you, you are at the wrong tire shop. Teslas use the 433MHz sensors used by a boatload of car manufacturers. They aren't unicorns.
    • Disagree x 2
  3. dale_cooper
    dale_cooper Member
    Columbus, OH
    Sorry, but you're misinformed with regard to the Model Y. The model Y is using a new type of bluetooth TPMS that is unique and you can only get it from the service center @ $300 total for all 4. With model s, x, 3, etc - other tpms sensors, like the versions discount tire would provide, worked great. They WILL NOT work on the Y, and right now, you MUST get the OEM part from tesla.
    • Like x 4
  4. DaveORD
    DaveORD Member
    Chicagoland
    In case you missed it, starting with the MY Tesla changed the TPMS to their own proprietary 2.4 GHz Bluetooth version. Only way to get them at the time I tried was to buy from Tesla. Nobody and I mean nobody had a third party TPMS that I could find that would work with the MY. Maybe that changed recently, but every place that is selling TPMS for a MY is buying them from Tesla. Discount Tire would be no different.
  5. Lozzy
    Lozzy Member
    NC
    The TPMS can be added now if you purchase from TireRack for $80 extra, total of $380. So they are making a nice little profit for convenience.
  6. ryanneves
    ryanneves Member
    Panama City, Fl
    I'm having a heck for a time finalizing my martian order for 8.5 or 9.5 20in wheels. 8.5 I'm liking the 245/45 20 idea verses just a 255/40/ 20 or even 265/40 20 on the 9.5. The 8.5 I think it that config would give a little more cushion for the side and smaller width may make it feel peppier. any thoughts?
  7. ryanneves
    ryanneves Member
    Panama City, Fl
    can you tell any ride difference from the 21s
  8. Lozzy
    Lozzy Member
    NC
    There is definitely an improvement but it’s still a stiff ride for sure. The suspension does seem to have a lot less of the bottoming out jolts but I don’t want to oversell the improvement. I still plan on getting coil-overs in the future.
  9. DFibRL8R
    DFibRL8R Active Member
    Leesburg Virginia
    Too soon to tell, will do a road trip this weekend and update. So far around town they are fine.
  10. DFibRL8R
    Leesburg Virginia
    No noticeable difference from the slightly larger diameter. I do like the look, the tread pattern is more prominent and visible from the side making them look a bit more rugged.
  11. DFibRL8R
    Leesburg Virginia
  12. Painkiller89
    Painkiller89 Member
    Any different in performance between 19 vs 20 wheels? The guy at martian said 20's are better.
  13. TwoK4drSi
    TwoK4drSi Active Member
    DFW
    And they weigh 26lbs :eek:
  14. ryanneves
    ryanneves Member
    Panama City, Fl
    BE78AB73-089F-467F-B972-7E35C6488B94.jpeg 440ED07F-EF55-494A-BCB9-28FF51B75D24.jpeg Finally got her new shoes installed. Martian 8.5 x 20s with 245/45/20 tires. Super happy with how they look.
    • Like x 5
  15. N2B8
    N2B8 Member
    So Cal
    This weight is for what size wheel? 20x9.5?
    Their website says 23lbs. I thought about them at first until I realized they were posting 1-3 lbs less weight on their website. Too bad most buyers don’t pay attention to this scam thinking they got “light weight” wheels. Very shady.
  16. TwoK4drSi
    DFW
    #96 TwoK4drSi, Dec 13, 2020
    Yeah. 20x9.5. Apparently everyone here thinks it’s “ok” so go ahead and order.
    Side note...scrolling through the pics here and on FB the face of Martian stays the same and there’s no concavity. The back wheel pad actually grows larger or smaller based on offset so that really tells the tale they’re flow formed but hey....what do I know.
  17. Jmeitz
    Jmeitz Member
    St Louis
    22lbs for me 19x9.5
  18. Cmf2455
    Cmf2455 Member
    NEWTOWN, PA
    Are Bridgestone quiettracks goid for all weather?
  19. kadify
    kadify Member
    colorado
    What does that mean?
  20. TwoK4drSi
    DFW
    #100 TwoK4drSi, Jan 3, 2021
    It’s pretty simple. Full forged wheels have deeper concavity for different offsets. See pic below. The shape of the wheel gets deeper but the material stays more / less the same. Hence same weight ~ 1/2lb difference between offsets. It’s just stretched inwards so the “pad” face in essence comes closer to the hub and the wheel face comes outward more but no more material is added to the wheel. If you look at other full forged wheels you can see concavity clearly. They physically have to make a different design for the face to achieve this. 409D7C3C-E5D0-48CC-BD37-8D739F641A11.jpeg
    Now what flow formed wheel manufacturer have is one barrel and one face only AND they add padded area. See example below. This achieves offset BUT the lug nuts holes are deeper. This in essence creates a “lower offset” but no concavity. The red is the standard wheel face. The purple and green are add on “pads” to achieve the lower offset while keeping the wheel face where it is. That adds weight and you can’t hide from that!
    I’m sorry but if it looks like a duck and smells like a duck....(missed weights, difficult lug nuts holes, same face profile).
    You don’t have to believe me but the proof is in the pudding. TONS of info floating out there in the model 3 Martian forum and all I am doing is make known a lot of things don’t add up. Good luck and be careful on who you chose.
    • Disagree x 1
