Master Charger - RH - 1st Generation
ASY - CHRGR - SEALED - 10kW - (6009278-84-F)
I later found this video
You mentioned you had the symptoms, what are the symptoms of a Master Charger going bad?View attachment 271796 I recently had the master charger in my 2012 Model S replaced at the Tesla Service Center in Indianapolis. On the invoice it is listed as...
I later found this video; the symptoms are exactly what I experienced. I suspect the problem is one of the 50 fuses as shown in the video, which seems like a very straightforward repair. However, I have not taken the unit apart to verify this. I’d like to get at least $800 for the unit; new they cost $2000, and remanufactured they are $1600. Let me know if interested. View attachment 271795
I just went thru this. Error I got was unable to charge. My hpwc would attempt to initiate but it would just click and retry then eventually just end up with red ring. I replaced both a50p50-4 fuses that are inside the onboard charger and its all back to normal now. I have 4 extra fuses just in case someone local needs them or if I end up needing them again. Its not difficult to change them out but you need to follow all the safety steps when dealing with the high Voltage systems in a tesla or other ev.You mentioned you had the symptoms, what are the symptoms of a Master Charger going bad?
The symptoms were mainly the red ring that would illuminate around the charge port after after several attempts to start charging. I could still supercharge, but that wasn’t really convenient for me, so I had the charger replaced.You mentioned you had the symptoms, what are the symptoms of a Master Charger going bad?
When you checked the continuity for all the fuses did they have continuity or were any of them bad? (With multimeter)I just went thru this. Error I got was unable to charge. My hpwc would attempt to initiate but it would just click and retry then eventually just end up with red ring. I replaced both a50p50-4 fuses that are inside the onboard charger and its all back to normal now. I have 4 extra fuses just in case someone local needs them or if I end up needing them again. Its not difficult to change them out but you need to follow all the safety steps when dealing with the high Voltage systems in a tesla or other ev.
Were your fuses bad???? I really need to know… Mine seems to be directly related to the temperature. When it gets too hot it’ll stop charging but if I let the car cool down it’ll charge no prob.The symptoms were mainly the red ring that would illuminate around the charge port after after several attempts to start charging. I could still supercharge, but that wasn’t really convenient for me, so I had the charger replaced.
One fuse was bad. Take them out and check them.When you checked the continuity for all the fuses did they have continuity or were any of them bad? (With multimeter)
