jebinc
Back on Topic - A great 50.7 Visualizations Video
Older versions of TACC used to wait a wee bit longer than it does now, and then rabbit up to the set speed (or as close to it as the car ahead permits). People complained about that. Now it waits less, and does a (more efficient!) chauffeur-like smooth rollout. And people complain. There's no pleasing everyone.
You have to basically be in the process of running the light for it to go off. Per youtube most have had success if you put your car on autopilot and use the scroll wheel to bring the speed to 0 right a stop sign (do not touch the brake or accel), then use the scroll wheel to increase the speed to go through the light/sign without touching a pedal.How is stop sign and stop light detection working for everyone? My car will visualize them like 100% of the time but I rarely get the warning anymore when I let AP slowly drive through one (safely, of course).
I have noticed that very few are going from 50.1 to 50.7. 50.1s are being upgraded to 50.5. 50.5s are being upgraded to 50.7. Based on that it seems they are incremental. In other words 50.7 builds on 50.5 not replaces it per se.
Oh you may be on to something with that. I read on reddit that someone measured 40.50.7 at only ~86 MB so it may very well need 40.50.5 to be installed first and if people aren't on 40.50.5 yet, that explains why 40.50.7 looks to be stalling out until everyone gets up to 40.50.5. I am on 40.50.5 and 40.50.7 isn't an option to me as of this morning which is a bit weird since I usually get updates a day after they hit wide release.
I just checked TeslaFi now and see several vehicles reporting updates directly from 2019.40.50.1 to 2019.40.50.7. I wouldn't be surprised if there are some cases of updates requiring a specific version currently installed but those seem to be fairly rare. From my own observations checking on download sizes of updates the update size can vary depending on what version you are upgrading from. If 2019.40.50.5 to 2019.40.50.7 only weighs in around 86MB then it's likely an incremental update specifically from going between those versions. The update package from 50.1 to 50.7 should be a different file that gets downloaded from Tesla.
This may deserve it's own sidebar thread as I've seen others mention it here but its getting lost in the noise, but I believe since this christmas update, supercharging on my M3 SR+ seems really slow.
I've only started my two supercharging sessions at a lowest of 53% with preconditioning in 30 degree temps. So o don't expect to see the newer 110kwh limit that came with the prior software But twice now and granted it's the same supercharging location each time the max I'm seeing for the charge rate is 24kwh.
When first plugging in the time estimate seems to guesstimate it would charge quicker but just stays at 25 minutes remaining for 5 to 10 minutes.
I was at a v2 charger and not sharing with the stall next to me.
Understood and it was two different stalls on two different days. One of which was next to the transformers and this morning no other vehicles were charging at all.V2 chargers are variable within a station in my experience. It’s useful to move to a different charge stand if you’re unhappy with the initial charging rate. I’ve found success in parking closest to the transformer. I noticed that other Teslas seem to chose those stations if they are at the supercharger before I get there. I often get more than 100kwh rates with preconditioning at around 30 degrees. And I move stations about 33% of the time... it often works.
I expect V3 station to behave better..
On the prior software I charged much quicker and I'm sorry not exactly an apple's for apple's comparison same location same stall 90+ kwh.
Agreed and that seems to be baked into this software release and or I haven't solved all the variables but I figured by posting here for additional "yeah me toos" would either dispute my findings (I'm nuts) entirely possible or corroborate them.I've only supercharged once so I can't speak to that so much but something that is similar as far as rapidly supplying energy to the battery, regen, has really dramatically been reduced lately and like I said, it has actually been warmer than it was on earlier software versions where the regen worked as expected. It feels like they are trying to baby the battery now by limiting power input/output at temperatures that are warmer than I would have expected. My i3 which uses a completely different chemistry is nothing like this under similar conditions.
Interesting observation that cars can jump straight from 40.50.1 to 40.50.7. I wonder why the uptake for 40.50.7 has been comparatively slower than to 40.50.5? I would think they would turn off the pipe for 40.50.5 once 40.50.7 is released since there is no reason to waste the bandwidth when people are going to just go to 40.50.7 eventually.
I'm still 'stuck' at 50.5 and continued refreshes/checking the car for new versions is not showing .7
wonder if they put .7 on pause? its been days since .7 was out and I'm not getting it even though I'm 'trying'.
