This seems right. My late June build is quiet, and has a solid metal parcel shelf. You might find this thread interesting as well. Trunk Top panel
I ordered mine on Sept. 26, and it arrived the day before 6 weeks passed. When I first got the VIN I called my insuror to get a commitment, and the home office insisted on a year for the car. I told them 2019, and they later decided on their own that it was 2020. I had read comments on wind noise, and had set aside some $$ for the seal kit available aftermarket ... but I find that it is damned quiet and needs no silencing. Driving it here in snowy Wisconsin I find that it corrects quite nicely when the rear end steps out, and that weather below freezing (in an enclosed but unheated garage) eats a fair bit of juice even when parked. No surprise there, for even old technology lead-acid batteries lose strength when it gets that cold out.
9/26 order here as well for my 20MY. And yes.... 20s are very quiet and I'm pleased with the lack of noise vs. my 19. The only reason I would get a door seal kit is to keep door jambs clean.
@grankin the model year for all cars is encoded in the VIN. If the 10th character of the VIN is a "K", it's a 2019. If it's a "L", it's a 2020. VINs are controlled by Tesla and they are the only ones who control what model year your car is.
Note that they have apparently "corrected" the Stealth Performance numbers on fueleconomy.gov so now the Stealth Performance and the AWD match in efficiency and range. Was not the case two weeks ago. Just noticed the change today. So much for trying to use the 990 vs. 980 motor difference as an explanation...apparently there is no difference after all. Still no test cycle documents published for 2020 so still waiting on seeing whether anything has been voluntarily derated (I don't know whether they can derate efficiency as well as range (I don't think so?)...) Two weeks ago: Now:
Assuming you are pointing out the white cotton-like material. I've taken off all 4 door panels on my 4/19 build LR RWD. They look exactly the same.
i got my model 3 sleeper/stealth 11/16 and only drove about 40 miles first two days but i noticed that the wind noise on the highway was pretty high. i am ordering the seal that covers outside between the glasses so hopefully that will make the noise go away!
What's the month/year your car was built? Abstract Ocean reported that 2020 Model 3 don't have front door pocket lights.
Bought mine late August 2019. Built early July. Very quiet on the highway, came with a trunk mat, and grocery hooks, and lights in the door pockets.
FYI my AWD was built on Oct 8th but MY2019. It still has the frunk hooks, but the dead pedal is already carpeted.
Dyno tests are a simulation, they simulate driving. They don't simulate it well so you have to modify the numbers for the missing aero effects, temperature differences, and so on. So I'd say @Uncle Paul is very correct to call it a simulation. I'd also ask how you think 2020 Mid range numbers got in there. It's a config that isn't sold. I'd wager that a Tesla employee just submitted an entry for a car that doesn't exist without any specific testing of such configuration.
They are the same numbers from 2018 when they tested this model on the dyno. My point was just that all the numbers are based on a dyno result (which uses coefficients to simulate drag, etc.) at some point. I’m not aware that the results can be entirely simulated, based on what we see in the test documents. Has to be some real test article backing it up at some point.
I understand this but.......what mileage is it based on ...12k, 13k miles per year.......what about those of us who drive less than 5k per year......I wouldn't put it past our crooked governor to make EV owners to start taking pictures of the odometers......some insurance companies do this now, but I am sure there are ways to get around it.......in the case of Tesla, our "T" screen shows the vin number and the total mileage, so it would work......but then what is the tax rate to be used
Mine had to be in the transition period also, was a Sept 2019 build, has frunk hooks, no frunk mat, no carpeted dead pedal, has lights in door pocket, very quiet all the time.
