I was again now confrontez with the statement that I should approx once a month or at least every second month charge to 100%. Leave it for a while for the battery cells to settle and then drive it down to low.
This should preserve the battery as it will otherwise unbalance as not all cells will fill up evenly and this will damage the battery.
I don't normally drive more than 100 km per day and follow AKKEE recommendations and charge around the 50% and let it sleep at night around 25-30%.
Should it once in a while charge full or is it a Myth.
If true what us the right way?
If myth what is then true to do if anything other than keeping low SOC and small cycles??
No that is not wright.
The battery will not benifit or get preserved from a 100% charge. Period.
Balancing the battery when used as I do, around 30 to 55% is not needed. My car settles with about 4mV imbalance and this do not show any tendency of increasing.
Battery balance is done at the top of the range and increases rhe imbalance at low SOC. As balancing evens the voltage at high SOC and different cells have slightly different capacity, the imbalance is moved to the bottom. The only real reason for balancing is to ensure all capacity can be used( and that most of the imbalance is below the buffer limit).
The BMS might drift though, and tge Nominal full pack might get slightly off the actual value. For me it seems to show too high capacity by around 1kWh(1.2%), which isnt really a problem for me. Most often I anyway need to do a full charge due to a trip, which resets the BMS.
All full charges take a small bite of the battery, so by calibrating the BMS often you wear more on your battery. Most people are unhappy with the on screen range loss and “calibrate the Bms” to gain some range on the screen, but actually use up a bit of the capacity each time.
A uncalibrated BMS do not give you a lower range. The capacity is there but the BMS havent seen it.
Each full charge do not eat very much of the battery but still it is contraproductive in my eyes if it is done often(or too often).
In you case, you do not have very much degradation I guess. If you stay low( as per earlier tips) the real capacity will stay very close to this for long, and the degradation will be very slow. Only if you see that the range have changed much more than you’d expect you should do a BMS calibration.
The guys that recommend monthly BMS calib. most probably have lower range than they like, and know a calibration might reset a few km/mi. You wont see very low numbers if you stay low.
