I honestly can't figure out how to take the picture of the battery pack. See attached image from right front wheel. The only hole i find is the one in the top of the attached image (from my video), but my phone can't fit in there... (quite small hole)
Since Tesla claims 580km for Europe, aren't we supposed to be able to see this somewhere for a LR 2021?
No, Tesla doesn't show WLTP anywhere. They use their own constants to display range, which they also change a lot.Since Tesla claims 580km for Europe, aren't we supposed to be able to see this somewhere for a LR 2021?
Perf 2021 with 20”: ????
We don’t have the data yet. The only capacity reported I have seen has been 80.4kWh. Constant is currently 162Wh/rkm but have not seen the result after the 2020.48.12 update. If it changes (it probably will), we can assume it is the final value - and then multiply that by 507km (315 miles) to get the approximate final capacity limit.
I know it's confusing, but right now I'd say 162Wh/rkm, with range of 499rkm, for capacity ~80.7kWh.
The numbers will adjust.
Got it
1104423-0L-P
I have SMT-scanned three M3P refresh now and the rated consumption on all three has been identical at 15.44KWH/rKm.
Sounds about right. My average consumption (dashed line) is 148Wh/km, and that's just below the hard line.You’d have to clarify what you are quoting here. Remember the discharge rate is different than the charge constant by 4.5%, due to the buffer.
So each DISPLAYED rated mile would be expected to contain:
161.7Wh/rkm*0.955 displayed rkm/rkm = 154.4 Wh/rkm
Remember, the calculation of rated miles at 100% conversion to battery capacity only applies at 100%. Because displayed rated miles are not equal to EPA rated miles, in energy content.
I hope this explains your observation - it appears to match exactly and I am not surprised by your 154.4 number.
If someone drives from 100% to 0%, they would use about 154.4Wh/rkm *495rkm = 76.4kWh. They would have the 4.5%, 3.6kWh buffer remaining still. For a total of 80kWh.
The range of 499rkm that I quote may be wrong...it’s possible it is a little lower right now at 100% but I have no way to know. But it is above 495rkm.
Any other tests you'd want me to do?
This is basically how I've calculated with all the SMT Data gathered in Germany from the Refreshed LR LG, LR PANA and Performance.
Yes, using Nominal Full Pack = Full Pack When New is just theoretical to compare with the same values and to have an idea what the highest theoretical rated range indication would be. Otherwise I wouldnt know how to get to comparable results and indeed the LG Packs with 74.5 KWH have been seen to max out at that capacity 74.5 KWH over several charging sessions. Something I doubt we will see with the 82.1 Panasonic packs.
I can buy one, any recommendations?No, if you don’t have SMT, you’ve done your part! Thanks and Merry Christmas.
What a Christmas present from you to this thread, lol!
I would love an excuse to take a day-trip in my Christmas present
2021 Performance Model implement same efficiency improvments than 2021 LR, so I think that 2021 Perf couldn't have 162Wh/rkm constant like 2020 Perf model.
