For us noobs what do you make of the post from this am that the voltage sag was the same at 30C
As was mentioned earlier, crudely constructed approximation of what is happening:
Vmotor = Vopen - Imotor * Rint
Pmotor (input) = Vmotor * Imotor
Vmotor is what we see in these data sets. You can't see Vopen unless the battery is open circuited - it's internal to the battery. But it will be related to the SoC.
Rint is the internal battery resistance.
So: if Rint is much lower at higher temperature (and it might be, if you can get those electrons pried off those lithium atoms much faster at high temperature), you can have a higher current Imotor and achieve the
same Vmotor at the same Vopen (Vopen being the open circuit voltage - the unloaded voltage corresponding to current SoC).
@eivissa would have to tell us whether the indicated power also aligned with Bjorn's videos - but it doesn't look like it. He indicated 278kW at 28.5% and 238kWh @ 20%, which compares to 220kW and 154kWh in Bjorn's videos at similar SoCs, but I'm not sure these numbers are directly comparable (he could clarify whether they are).
And just as a reminder, you have to remember there is not a direct relationship between 0-60 time and peak power, because peak power (when it's at its maximum at 100% SoC) is only reached at ~45mph - so you don't actually (theoretically) have a hit on your 0-30 time, even at pretty low SoC, since you're
not power limited at those speeds (e.g. it requires approximately
zero HP to launch massively hard in a 3P+ - you just need the torque!). It's a bit more complicated than that - you need to be able to deliver a lot of current to get that initial torque too, but those are details which we can gloss over here, as it is off topic. Anyway, there are plenty of curves out there showing power vs. speed at different SoCs, so you can look them up and verify all the details of how SoC affects power for yourself. To the point here - it would be much better to see that data for all these cold weather runs, rather than the simple table below, because you could see the overall effect of temperature throughout the run, and we might learn something.
