tintinfish
WELCOME TO THE LOTTERY, U.S. !
Tesla Model 3 82kWh battery pack confirmed by California Clean Fuel Reward website - Drive Tesla Canada
is there a way to find out the total battery capacity without tapping into the BMS?
Yes, when you are at 80% charge or higher, take a picture of your energy graph screen along with rated miles and percent on the battery icon (need to switch display setting to get both). Then post it here.is there a way to find out the total battery capacity without tapping into the BMS?
Nope, still showed 500km inside the car.
You are wrong time and time again and you still continue. Some people simply never learn...
German Model 3 Performance Refresh SMT Valu
81kWh per EPA, showing up in SMT with ~80kWh max, and with a degradation threshold of maybe 79.5kWh.
The only sure way is to charge to 100% and drive steadily at anywhere between 60-85mph to near 0% or until the car stops, then read "used kwh since last charge".is there a way to find out the total battery capacity without tapping into the BMS?
Here is the full SMT Bat. data of the German Model 3 Performance Refresh:
Hi eivissa (lovely place), i'm following you and the others on TTforum but unfortunately with google translate. Thanks for you info and please add here the new info the forum is collecting!Here is the full SMT Bat. data of the German Model 3 Performance Refresh:
Is this your vehicle? If it is, could you pretty pretty please take those two pictures of the energy screen?
It looks to me like they haven't settled on the correct constant yet.
If you are more precise about that energy screen reading I might be able to convince a german owner to get the pictures.
Bare in mind that the battery was very cold and he hadn't driven and charged (only 2,3KW from the wall) the car much at that point.
Capacity when new is the value provided by the can bus and on the old batteries it was pretty close to reality(nominal full) when new. Only the lg and the new batteries seem to have bigger deviation. Might be just how they are built, with more top buffer.
First post here is an example: 2021 Model 3 - Charge data
It's really easy, but it's critical to do it at a high SoC (80% or above is best, 100% ideal but definitely not required).
And it's key to get the % AND the rated range in quick succession. Need four numbers:
%, Rated Range, recent efficiency, and projected range. This requires two pictures. Ideally in km (more accurate).
He has 2021-refresh for sure,
- could not have the quoted numbers (original or new) make sense for a new 2021.
Hello,
Thanks a lot for these informations, i'm reading this topic everyday
did you find something about the battery sticker ? What is "BB" ?
