I have a Wallconnector connected to 3phase/400V.
-Yes, I have the charge set up to commence at 0330 during the night. If I have been at a normal working day my SOC is about 30-35%. With the charger set at 11kW it takes about 2hrs to charge to about 56%.
I always connect the WC when I park it in my garage. Charging will take place every night.
The choise of 1,3 or 11kW charging power is mostly a question of the supply to the charger. There is a slight difference in charging efficiency but these charging rates is considered slow charging( less than 0.25C) anyhow and you would probably not be able to see any difference in degradation due to this.
I got my M3P at the last new year. In hour very cold climate i started with 80% SOC during the coldest (-30C) days. When it got less cold I lowered the SOC successively and ended up at about 55-57%. As I’m a less newbee on my Tesla for the upcoming winter I might use a lower SOC during the cold days.
The li ion battery degrade less from time at lower SOC and also less when using smaller discharges(charge often is better).
I think my teslafi range chart speak for itself about low degradation. The average fleet line is usually one to three other MP3’21, depending on these cars odo readings.
Started with a NFP of 80.7kWh the day after delivery and it still is at 80.7. The NFP is affected by the charging habits and higher SOC seems to push the NFP down.
Disclaimer:
I do not think anyone need to work hard to keep degradation low. You’ll be fine anyway.
I’m interrested, partly because of a hobby where I use different lithium batterys and started reading, when I ordered the M3 I started reading research reports again about li ion in general and NCA in particular.
I decided to use my knowledge to keep the degradation down, mostly for fun and not to the extent that It impact the fun part of having a Tesla.
@ Ro_explorer: you might be able to get less degradation and a clearly higher NFP when you get your wall connector.
