I love seeing insanely high upstream network traffic from the Model 3. Means I did something useful to Tesla today on my drives I'm seeing uploads that go beyond just my snapshots. Unless snapshot size got bigger with 10.5.....
I run into the same situation as OP that you quoted often enough that I’m checking the mirror while approaching any busy intersection (stop sign / stop light). Disengaging is the best if you can do it quickly and coast the rest of the way using regen / normal braking. Modulating early braking with the accelerator is hard because if you don’t let go gently enough it’ll slam the brakes again, making you look stupid twice in a row hahaDo you have an accelerator and a way to disengage if necessary? Or did those disappear in 10.5 too? No need to brake early. Just press the accelerator to get through it, possibly while disengaging.
Besides the update I recalibrated cameras, reset the screen and powered off/on in that order. Drives were actually very good after that. Certainly my best drives regardless of FSD version.Tesla pushed out the update again and that helped alot.
In summary as bad as 10.4 was 10.5 is a welcome improvement. As I read thru other postings it still is amazing how much variation there is from one car to another.
- In my neighborhood with several tuns only .1 mile apart FSD did not speed up as quickly only to have to brake hard to make the next turn. Nice.
- Slowed down much sooner on sharp corners. Previously on 1 corner it would try and take it at 35mph only to drift into the other lane before slowing down.
- Improvement at 3 and 4 way stop signs
- General improvement on 90 degree turns. Much sooner with very little jerkiness.
- Rotary, almost managed to enter without stopping but at least the delay before creeping forward was less. Still a lot of improvement needed. The only way to really test it is to make sure nobody is behind me. Easier said than done.
- Seemed a little quicker to move into the right lane
- Smoother stops when approaching lights.
- Very little phantom braking/slowness but that maybe because the drives were at night. Will see what tomorrow brings.
almost certainly due to local roads rather than the car. Majority of early beta testers (pre safety score) seemed to be west coast, so I reckon of your local roads are like that you may have better luck.As I read thru other postings it still is amazing how much variation there is from one car to another.
Just saying you can intervene anytime; there’s no reason anyone has to know you are using FSD Beta, and in fact for Tesla, it’s best that no one knows. They get the best data that way I suspect, if there is any value in that data.What does this even mean? Was it supposed to be sarcastic or something..since when I translate it back to Russian it usually gets lost. I’m pretty good with humor but sarcasm is harder for me.
My 2017 X definitely says TWO. I wouldn't be surprised if vehicles with no interior camera say two while vehicles with an interior camera say three.EVERY time, I do and I sent a bunch of increasingly NASTY bug reports… at one point I think I MIGHT have even said “what is this s..t” but hopefully, I didn’t actually.
On another note. I noticed that my 10.5 FSD release notes said that one had THREE disengagements before it would revoke FSD, but I’ve read that some people say It’s only TWO. Are there different thresholds for different folks, cars, drivers? Does more chances mean you’re a WORSE driver or a BETTER driver?
I have an interior camera and my control panel says 2. Unfortunately, I‘ve already had one disengagement - eyes on the road, hands on the steering wheel but was on the phone so I didn’t notice the command to apply slight turning pressure on the yoke. As a result, I use FSD very sparingly now.My 2017 X definitely says TWO. I wouldn't be surprised if vehicles with no interior camera say two while vehicles with an interior camera say three.
What does TomTom navigation show ?There are also a fair amount of issues I've encountered that can be blamed on bad map or navigation data.
Here's an example of what I've been emailing [email protected] after capturing a video clip. I hope this gets to the right folks as I think these types of issues should be easy to address...
Date and Time: 16-Nov at about 609 PM, Video clip captured.
VIN: xxxxxxxx
GPS
39°56'17.9"N 75°21'01.8"W
39.938313, -75.350501
Navigation from northbound Sproul Rd to Southbound Highway 1 can be done via a left at those GPS coordinates (it is a traffic light).
In-car Nav recommends continuing North and then a U-turn.
In-car
Google Maps (correct) routing:
Had a comparatively bad drive in the morning dropping off kids.
Its the same route I've done 20x over the last month with FSD - there is some variability, even with same release. So, have to wait for a few more drives for a reliable report.
- On the first right turn from stop, suddenly jerked the wheel to the left - so got disengaged. While I've written a lot about the jerkiness when turning right from a stop, none of the wheel action has been this much.
- At an intersection where the side roads have stop signs, the shoulder starts out very broad and then narrows. On rainy nights, the car had got confused once and gotten into the shoulder - but today in broad day light on a dray day, the car decided to use the shoulder rather than the lane it has taken every day. Second disengagement.
- At a signal when going straight, the car decided to go only 100 ft or so and then stop. Not sure what happened - had to take over. Unfortunately hadn't turned on the camera. So, third disengagement.
Apart from the above 3, had some usual disengagements.
- At a traffic signal where the car needs to turn right, it is supposed to be no-turn on red (the signal says "right turn signal"). But most people turn and honk if someone doesn't. Had to disengage here because, the car stopped well short of the intersection and for me to even press the go pedal, I need the car to creep. Not sure we can control the creep by pushing the go pedal, without the car deciding to take off at the wrong time.
- Roundabout that is not in the map
Other observations ..
- The car seemed to keep more to theleftright on unmarked roads. Could be just the normal variability.
- When finishing the drive at home, the car came closer to the curb. New behavior or just by chance ?
- Turns when already moving have always been variable. Some smooth, others jerky. Today all the turns seemed jerky.
So, on the basis of this one drive, I've to say 10.5 was worse than 10.4. But need more observations to confirm.
Same here. Almost never using FSD now since the phantom braking is SO ANNOYING.Just had an absolutely awful drive. Roads were rural two lane roads, well marked, speed limits of 55. Phantom braking was the worst I’ve seen yet. It was sunny, no clouds, perhaps it was braking for shadows cast from trees, or differences in pavement colors (darker vs. lighter, where a section of road was repaired). FSD was basically unusable. The phantom braking was not the 1-2mph slow-downs, but rather 10-25mph slow-downs.
Other phantom braking: seemed to slow when approaching intersections or passing them. Seemed to slow for parked vehicles in driveways. Again, these were 10-2mph slow downs.
There were not many turns made, but the one right turn which it should have no issue with was terrible. Car stopped as if there was a stop sign, and would not complete (or even start the turn). I had to gas it for it to complete the maneuver.
It’s strange, I don’t have an issue with phantom braking in more dense areas or expressways, it’s on these rural roads where I see it the most. Sucks, cuz that’s were I live.
Edit: on curves to the right, still hugs the center lane markings. Car keeping too far left on those curves.
Ditto, ditto, ditto ditto, dittoJust had an absolutely awful drive. Roads were rural two lane roads, well marked, speed limits of 55. Phantom braking was the worst I’ve seen yet. It was sunny, no clouds, perhaps it was braking for shadows cast from trees, or differences in pavement colors (darker vs. lighter, where a section of road was repaired). FSD was basically unusable. The phantom braking was not the 1-2mph slow-downs, but rather 10-25mph slow-downs.
Thats interesting - I wonder why this happens.It’s strange, I don’t have an issue with phantom braking in more dense areas or expressways, it’s on these rural roads where I see it the most. Sucks, cuz that’s were I live.
