MASTER THREAD: Aftermarket Wheels on Model 3
KenInDaLand
7
9
Cleveland
Here’s a couple pics I took today while doing some yard work. Stealth with 35% tint. 20” Vossen HF-5s on Micheline Pilot Sport A/S. 235/275. Tsportsline lowering springs.
jkoya
NA2 NSX
Nov 21, 2018
3,626
1,553
Northern CA
Hopefully a last pic of my winter setup while I wait for my summer wheels to arrive.
Gramlight 57dr 18x8.5 et35 in gunblue. Wrapped in Michelin x-I’ve xi3 245 tires.
Nice - I like your winter setup !! Those wheels look like they would be quick to clean. What are your summer wheels going to be ?
Burrito
581
408
New jersey
summer setup will be stance sf07 in 19x9.5 at all corners, 265 tires. my avatar pic is from last summer. staggered vorsteiner 20s 107s
Firehuntah
546
317
The Netherlands
With the lovely weather here now I finally swapped to the summer set as well on my Model 3. Fitment still isn't the way I want it to be just yet (couldn't change ET on these wheels), they'll be pushed out a bit with spacers. The plan was to have these spacers already before swapping the wheels but unfortunately it's taking a bit longer to have them made. So for now only some pictures without the spacers. ;) It already looks much better now it's been lowered though (-20mm of Cobra Suspension). The wheels are Rosenstein Delta 18" in matte bronze (imported from USA as they weren't available here).
pdx_m3s
1,231
1,054
Portland, OR
Yes, the tire need to be dismount and swap around. The tire shop usually charge about $25 per tire (depend on the area) for mount and balance. It's basically $100 for tire rotation.
A better, more efficient way to do a slight stagger like this is with a small 5-7mm spacer. You get the fitment of the staggered offset and the ability to rotate tires easily... and most importantly, you don't have to make it a multiple hour long affair with a tire shop. I don't know about you, but I have a hard time trusting tire shops with a nice set of wheels. I've seen and had too many come out with slight blemishes and scuffs because of their handling and machines. Many tire shop machines use incredibly destructive "grabbers" (the little pads that grab the inside of the barrel) to fasten the wheel to the machine. Also, not sure what it's called, but the big collar nut that holds the wheel to the balancer is likely to leave marks on the face of the wheel.
