MASTER THREAD: Comprehensive Road-Course Modification Guide — Optimizing the 3 for the track
Discussion in 'Model 3: Driving Dynamics' started by MasterC17, Nov 13, 2019.
  1. Vines
    Vines Active Member
    Silicon Valley, CA
    Keep the PS4 pressures at 36 at the lowest, they do not like low pressures and will chunk fast.
    The stock pads are ok on the track but are not track pads they are EV pads and if you are replacing fluid I'd do pads too. If you use them hard you will cook them, though you will get warnings. I recommend the Unplugged pads a good street/track combo. There are also many other compounds that may be cheaper. Its $600 well spent imo.
    The rears are actually quite stressed simply because of how hard they work as the E-diff.
    Have a blast and know that if you engage track mode you absolutely can lose control. Be ready for that and slowly find the limits if you don't have much track experience. At Laguna Seca I forgot that the last time I used track mode I put it on "Drift Mode"
    When I engaged track mode I missed that the sliders were set to -10 TC and full rear bias. I promptly spun and puckered myself.
  2. Electric Dream
    Electric Dream Pilots the Millennium Milkfloat
    UK
    The stock pads are a waste of time. I wouldn't bother with Unplugged pads.
    Get some tried and tested compounds such as RB XT970 or Carbotech, otherwise you're going to waste your day.
  3. Mash
    Mash Supporting Member
    Prague
    Stock pads and tires are going to be a problem. 4S is very soft and gets hot fast. But stock size of it is miserable for the weight and power. I destroyed them way faster than stock pads. It sounds tempting to be careful, but I don't see it's possible to be that careful enough. I was getting them +20psi vs hot - it's too low cold and too high hot within the same session with cool down laps.
  4. SK360
    SK360 Member
    Pittsburgh, PA
    265/35/19 RE71R are an absolute steal right now on tirerack so that’s the direction I’m going this season. Also just ordered 19x10 +35 MRR M600’s (same wheel @Rexpelagi runs, flow formed 24lbs) which are also on closeout due to the style being discontinued by MRR. Should be a good upgrade over my 255/40/18 on 18x8.5
    With the wheels and tires both being on closeout I’m $1580 out of pocket for the setup. Figured I couldn’t beat that.
  5. MarcG
    MarcG Active Member
    San Francisco
    Saw that, but it says “2018 production”. Any clue what that means?
  6. SK360
    SK360 Member
    Pittsburgh, PA
    Probably are 3 years old. But stored properly (Tirerack does this I’m sure) and not being heat cycled I wouldn’t worry about it.
  7. mcbarnet007
    mcbarnet007 Member
    San Jose, CA
    the ones I got have DoT of 2018 49th week. Not too bad.
  8. Mash
    Prague
    Unfortunately, rubber is losing felixibility not only from temperature, but from oxygen as well. Especially very soft rubber. Unless it's stored without oxygen access, it will become harder over time. I had barely used R888 and they became zero grip bricks after 5 years.
  9. mcbarnet007
    mcbarnet007 Member
    San Jose, CA
    If it's brand new, it will last longer because of the mold release that's on top of the rubber coming out of the factory.
  10. MasterC17
    MasterC17 Active Member
    The Hankook RS4's I bought last year were a 2018 production date that I used in 2020. I didn't think it would be a big deal, but either the RS4's are basically like driving on a rock until they are HOT (like 2-3 laps) or their age was showing - maybe a little bit of both; I was NOT impressed with that tire. I'm normally one to look for a deal, but I don't think I would buy old DOT tires again. Just my two cents.
  11. SK360
    SK360 Member
    Pittsburgh, PA
    Luckily a tire engineer from Bridgestone is hidden among us here and told me before I ordered....
    “Ya should be fine, it becomes more of an issue if it's heat cycled first”
    Not too worried about it, will be fine for parking lots ;)
    I think that’s normal for RS4’s. A local guy runs 265 RS4’s on wider wheels and I beat him easily all season on 255 RE’s on my skinny wheels. Then he got a codriver/tire warmer for the last event and gapped me by a good amount.
  12. superflyrolla
    superflyrolla Member
    Waterloo, IA
    Tire Rack had the same deal on 2017 245/40/19 RE71Rs last year, so I ran those. They were awesome for autocross, so I didn't hesitate to jump on those 2018 265/35/19s this year. I don't have a direct comparison to the 2020, so take my comment for what it's worth.
  13. SK360
    SK360 Member
    Pittsburgh, PA
    Date code 5118 and 4618. Not bad.
  14. MarcG
    MarcG Active Member
    San Francisco
    Ok I’ve been convinced! New set of RE71Rs ordered (even though my current set only has 2 track days in them..)
  15. mcbarnet007
    mcbarnet007 Member
    San Jose, CA
    Looks like they're out
  16. Ravire
    Ravire Member
    Orange County
    Quick question what rear pads should I get that would be a good combo for the mpp track pads I have in the front? Mostly street driving on twisty roads but I want it to be usable on the track as well. Seen a lot of options people use and don’t know what to go with.
  17. MoreAgain
    MoreAgain Member
    San Diego
    I've had good results with UnPlugged rear pads with MPP front track pads and rotors.
  18. Ravire
    Ravire Member
    Orange County
    That’s what I was thinking because I’m going to unplugged on Monday anyways
  19. Vines
    Vines Active Member
    Silicon Valley, CA
    I'm quite happy with my unplugged pads, except the small rattle due to lack of spring clips. I plan on using high temp double side tape to stick them to the pistons and the calipers, next time I go into the brakes that far.
  20. Lunares
    Lunares Member
    San Diego
    Unplugged pads are almost twice the price of carbotech (XP12/XP10). Do they actually perform worth the price?
    Any other pad the consensus for best track pad lately?
