LakeWorthB
Guy who just did my new 14-50 used a Pass & Seymour/Legrand. It has similar construction to the Hubbell and Byrant outlets pictured..
Does the Legrand receptacle have allen screws?
there is one listed on ebay showing standard screw headsDoes the Legrand receptacle have allen screws?
This thread has been massively helpful! Thank you @gilscales for compiling this info!
I had 3x of the Leviton Home Depot special 14-50's that I just swapped out for 3x Bryant 9450FR's. I had read other "be careful" stories on the forums and just in the past month my car started being thermally limited while charging at 32A and downclocking itself. Upon investigation the plug was certainly quite warm, and the black plastic of the outlet socket was developing a white residue. Not wanting to take chances I started researching and found this thread which gave me all the info I needed. Long story short, as many have said already, the Bryant outlet is of a much higher quality and you can tell immediately when you pick it up. I showed the old and new plugs to a few people and it was obvious to everyone which part was the more robust one.
It may sound weird but just the way the plug slides into the Bryant is so much better than the rocking and a bit of wiggling I'd have to do everytime with the Leviton. It's better in everyway, except price, but put into perspective a good plug is much cheaper than my insurance deductible for a fire.
Back story - New construction, only a couple of years old at this point, and trying to future proof things we had the builder add these 3 outlets, 1 for each garage bay and 1 outside for future guests. We forgot to get specific with the outlet and the builder's electrician just went down to HD and grabbed the outlet. Overall annoying but the problem is now solved.
It is very, very easy, just make sure you turn off the break first!How difficult is it to swap the outlet? My electrician just put a Leviton in... I was able to tell him a head of time what brand, just followed Tesla’s lingo for “high quality industrial grade.”
Here is the Pass & Seymour/Legrand unit compared to the BryantGuy who just did my new 14-50 used a Pass & Seymour/Legrand. It has similar construction to the Hubbell and Byrant outlets pictured..
*sigh* and he installed it upside down...
Ground should be on the top.
Not sure what code is on this but you will need to get or make something to suspend the unit above the outlet so you won't have a strain on the cord/plug/outlet, better off to get a nicer outlet (Bryant or Hubble) and kindly ask the Electrician to change it out if you do not feel comfortable doing it yourself as he did install it upside down, would not take him more than 5 min.Yep, pretty sure ground was on bottom (I'm at work right now).
How serious of a problem is this? Is it up to code to install it one way and just Tesla says ground up? Or if I call him back can I request they come out free of charge because it wasn't installed in the correct orientation?
What if I don't correct this?
The UMC won’t hang properly unless it’s plugged in with ground on top. Have him fix it. Here’s the installation guide from Tesla for 14-50 outlet:Yep, pretty sure ground was on bottom (I'm at work right now).
Yes this is good, you should have no problem with the mounting depth as the terminals are side fed, the other is probably back fed and would take up more room than the Hubbellhttps://www.amazon.com/Hubbell-Wiri...Hubbell+9450a&qid=1564714037&s=gateway&sr=8-1
Is that one suitable for the Tesla? I can’t find any local (which is probably why he used the cheapo one) but can get this in by Saturday and hopefully he can swing by next week to make the change and have ground on top.
Will this fit in a standard size metal box (whatever he has the Leviton in) or is there a difference box I can order in off amazon too?
Do not forget the Hubbell SS701 cover plate as the outlet face is larger
That’s the one, your old one won’t fit the HubbellGood call! Thank you! This guy? https://www.amazon.com/Hubbell-Wiri...r+plate&qid=1564720284&s=gateway&sr=8-1-fkmr0
yes a 5 or 10 min job at most for your electrician, everything should go in just fineView attachment 436815
I’m hoping everything will fit so this will be a quick adjustment where I don’t have to pay again or he just charges me for like a half an hour.
the 14-50 is the plug, 14-50R is the receptacle or outlet, all the 14-50 outlets will be marked with an RI think the last question... is there a difference between 14-50R and 14-50? I think from that amazon picture the Hubbell says 14-50R on it... that will fit the 14-50 cord Tesla sells, right?
