RKCRLR
It should. However sometimes bureaucracies screw up.Good info. I guess this applies to any utility company including SCE.
I guess it depends how form is filled out. If I get there, will try to do it exempt, but does not make sense to me, but, ...There was some questions raised if SGIP incentives were taxable. According to this they shouldn't be:
U.S.C. Title 26 - INTERNAL REVENUE CODE
However, some were concerned that you may still receive a 1099 for the incentive.
I asked the PG&E SGIP department if I should expect to receive a 1099 for my incentive.
They responded:
"It depends on how your application was submitted. If you are tax exempt, you will not receive a 1099."
So I asked Tesla how they filled out my incentive form.
They responded:
"Thank you for your email. We always fill out our customer applications with the “Exempt” status. That means you will not get a 1099."
So those of us receiving a SGIP incentive from PG&E should not expect a 1099.
You don't fill out the form, your installer does (unless you're registering yourself as the developer and are doing all of the SGIP "paperwork").I guess it depends how form is filled out. If I get there, will try to do it exempt, but does not make sense to me, but, ...
what form is used for batteries?FYI: it looks like Form 5695 is available for 2020 now: https://www.irs.gov/pub/irs-pdf/f5695.pdf
Although if you use a service like Turbotax, they're estimating it will be available for e-file starting 1/28/2021: Federal Individual Forms Availability
I never filled out that particular form (that I remember but Tesla isn't good at providing you completed copies of the forms). Tesla filled out everything and had me digitally sign them. They are all electronic forms. They don't send paper copies (that I'm aware of) but enter everything through the SGIP portal. SGIP sent me an example screenshot of the tax information fields on the portal when I asked about the 1099 information.So, here is the form. Are you saying we as a customer never sign this?
I got this from SGIP
the Contractor must complete the installation of the SGIP equipment and the Applicant must submit all required Incentive Claim Form (ICF) documents
Are we not the applicant?
what if batteries are installed after solar?Should be the same; as long as your batteries are installed with a solar system, they count under line 1. Qualified solar electric property costs.
I just talked to my installer co. This was one of the questions. I just sent him the form so he could look into an answer for me.I never filled out that particular form (that I remember but Tesla isn't good at providing you completed copies of the forms). Tesla filled out everything and had me digitally sign them. They are all electronic forms. They don't send paper copies (that I'm aware of) but enter everything through the SGIP portal. SGIP sent me an example screenshot of the tax information fields on the portal when I asked about the 1099 information.
ThanksProvided the batteries are configured to charge exclusively from solar it would still be listed there. For purposes of the ITC, the batteries should be thought of as a part of the solar-powered system - in this case a later add-on, just as if you added additional panels to the system. (To further this point, if the batteries were installed in conjunction with a wind-powered system instead of solar-powered, as one member has documented doing, if claiming the ITC the batteries would be included on line 3 instead of line 1.)
I got info from Self Generation Program <[email protected]>Thanks for info. When you say SGIP send you that form , did you mean from [email protected] or SGIP equivalent email of your utility provider?
According to the proposed legislation from Representative Mike Thompson (D-Calif.), the GREEN Act would reinstate and extend the solar investment tax credit (ITC) to 30% for projects that begin construction after 2020 and before 2027, then phase down to 26% for projects that begin construction in 2027, 22% for projects that begin construction in 2028 and 10% thereafter.
Additionally, the GREEN Act would expand the 30% investment tax credit to include energy storage technologies with a minimum capacity of 5 kWh through 2026.
Overall, while I think it is great that attention is being paid to climate change, I am not entirely convinced that upping this credit and extending it for so long is necessarily the best approach - it seems like it has done its job to improve the technology and bring costs down, but extending it this far may serve to push out demand rather than encourage it.
Does this mean that we could receive further discounts on the Powerwalls?
What are your thoughts?
