Msjulie
cool - ok how do you get them back out? once started I get it but where do you lift to remove the 4 stands?
Um....how else would you support a car with four jack stands?That looks unsafe
Two pair of Jackpoint stands. Jack stands with Tesla PadsUm....how else would you support a car with four jack stands?
Why would the tires wear unevenly side to side unless you have an alignment problem?
Every time I look on that website it says out of stock on everythingTwo pair of Jackpoint stands. Jack stands with Tesla Pads
Perhaps the pictures are deceiving me but it looks like the pucks are on top of a flat jack surface that could slide off. The jackpoint stand has a Tesla specific model with the centering pin. I plan on buying a pair. If I wanted the car up on four stands I'd buy two pairs. $300 for safe stands to put my $2,000 winter wheels and tires on my $63,000 car seems like a fair price.
If all you are doing is rotating tires then the above is an excellent idea. Putting the Model 3 on jack stands is more of a swap out springs and shocks or some other major work requirement in my opinion.I have been thinking that I should get a temporary spare to carry on road trips. Although I expect that to be more costly than your method, it seems easier. Just the floor jack, one Model 3 jack pad and the spare is all you would need to rotate your tires. It wouldn't be very fast, but then I'm never very fast on any car maintenance!
Another great idea to rotate tires front to back. The whole side of the car can be lifted from either lift point. The rear lift point works better on a RWD car. Lift using floor jack at rear lift point, place jack stand at front lift point, rotate tires, remove jack stand then lower and remove floor jack. Always torque lug nuts per manufacturer specifications.With a floor jack and one stand you could just do one tire at a time correct?
I thought about the wheel lifts but I didn’t want to have to store them.
However, the floor jack feathermerchan found is exactly what I have been looking for. Thank you for sharing!
