MASTER THREAD: Jack Points — location, use, damage, pads, etc.
So there is this jack+jackstand combination:
However, it says that the lift range starts at 8+5/8".
If you jack up on the front jack point with another jack, can you get the rear jack point 8+5/8" plus the height of the adapter high, put this jack+jackstand under the rear jack point, jack up on the rear jack point some more, put a jack stand under the front jack point, then lower it a bit and lock the jack+jackstand into jackstand mode? Or the same procedure starting with the rear jack point?
