amit_gunner
Yes. I have it set as sentry off at homeNice, with sentry off, I guess?
I have exact same range 433km now but only after 2600km. Lol. 2022 Model 3 RWD. its been about 3 months too10k update:
M3 RWD with LFP batteries
10,000 kms in 3+months.
Range dropped from 438kms to 433kms. My understanding is first 2km loss due to calibration, droped within first few weeks. So the real loss is 3 kms. Zero supersharging . Daily level 2 home charging to 100%.
So far so good
I'm not sure what settings you're using in the trip planner, but you can absolutely go from Chandler to Quartzsite without having to charge along the way. In warm weather with mixed driving, I routinely get the EPA range or even better from my LFP RWD.Help. We have ordered a 2022 SR RWD but just changed to LR since I’m concerned we will never get near the 272 (rwd) or 358 (lr) numbers. I have some real concerns on which vehicle to order. I can still change so any feedback on my ‘stream of consciousness concerns’ are appreciated.
LFP:
If I leave the car plugged in all the time am I likely to see 272 miles range? If not what range are you folks experiencing? (I’d prefer to plug and forget in our garage). How far can I go on a full charge (I know lots of variables but…)
If supercharging enroute can I refill to 272, or whatever 100% is?
Is it quicker to charge an lfp to 100% than an LR to 80%?
My concerns started when I tried to plan a trip on Tesla’s planner and I couldn’t go from Chandler Az to Quartzite AZ (<190 miles) without stopping in Buckeye! I also couldn’t go from Chandler to Flagstaff (165 miles) without a stop. If true this renders the charge estimates of 272 miles useless and the car just doesn’t have the range we want. Of note the LR with 358 miles of advertised range could do both, this caused me to change the lfp order to lr.
LR:
What is the max range I’m likely to see? clearly from the threads it looks like a lot less than 358 Miles
If I charge to 80% how much additional time does it take to get to the remaining 100% while on the road? In other words is LR an actual advantage Or do I really only get 80% of 358 vs 100% of 272?
our profile is town or long trips, no midrange use. Is LR worth it?
we want max range available but in a usable non fussy way if possible
thanks
LFP:
Yes, it'll take a long time and you'll typically never want to do that. Taper is better on LFP I guess but it's still a drag.If supercharging enroute can I refill to 272, or whatever 100% is?
Too many variables.(I know lots of variables but…)
I'd avoid using the Telsa trip planner on the website. It isn't as accurate as the car itself or A Better Route Planner.Help. We have ordered a 2022 SR RWD but just changed to LR since I’m concerned we will never get near the 272 (rwd) or 358 (lr) numbers. I have some real concerns on which vehicle to order. I can still change so any feedback on my ‘stream of consciousness concerns’ are appreciated.
LFP:
LR:
thanks
Speed really really kills range. Running that trip with my RWD would get me there with 20% left if I go 110% of the speed limit capped at 80mph, but closer to 12% left if I go 85.Help. We have ordered a 2022 SR RWD but just changed to LR since I’m concerned we will never get near the 272 (rwd) or 358 (lr) numbers. I have some real concerns on which vehicle to order. I can still change so any feedback on my ‘stream of consciousness concerns’ are appreciated.
LFP:
LR:
thanks
So assuming about 132Wh/mi of that is aero and most of the remaining 100Wh/mi is rolling resistance (probably not that bad an estimate), that works out to about 295Wh/mi at 85mph (most of ABRP route). So a bit lower than their estimates.Note: ABRP defaults to 247 wh/mi @65mph for the 2022 Model 3 RWD. With my personal 2022 Model 3 RWD I have measured 232 wi/mi at 70mph and 60 deg F. Maybe I have a fluke car, but I doubt it. I do run my tires at max psi though, so perhaps ABRP assumes you are at 35psi or something like that.
Same here. I recently got 211 at 65 over a 20 mile highway test I did. Temp was in the upper 70s too. Heck, I got 240 wh/mile going 65 around 38 degrees after I had super charged. ABRP is definitely conservativeNote: ABRP defaults to 247 wh/mi @65mph for the 2022 Model 3 RWD. With my personal 2022 Model 3 RWD I have measured 232 wi/mi at 70mph and 60 deg F. Maybe I have a fluke car, but I doubt it. I do run my tires at max psi though, so perhaps ABRP assumes you are at 35psi or something like that.
That 211Wh/mi might be slightly too good to be true...if it's not perfectly flat (or you do a round trip - did you?) it's tough to be sure, especially with tailwinds, etc. 225Wh/mi seems more like what could be expected.I recently got 211 at 65 over a 20 mile highway test I did. Temp was in the upper 70s too. Heck, I got 240 wh/mile going 65 around 38 degrees after I had super charged. ABRP is definitely conservative
I think the rang drop is not based on mileages. I have the same car M3 RWD with LFP 3000km in 3 months. The range dropped from 439km to 434 km.10k update:
So far so good
That's seems bit weired tbh. But I won't complain lol.. I guess it's still early to make any battery comparison..I think the rang drop is not based on mileages. I have the same car M3 RWD with LFP 3000km in 3 months. The range dropped from 439km to 434 km.
I've also have one with a 269 mile rated range at 5k miles. A 3 mile drop is really good. My 2020 MY dropped 15 miles in the first 5k miles. (Keeping in mind that the reported range isn't a great metric of true battery capacity.)My first post, another data point, M3 RWD 2022 is close to 5K miles, the range shows 269 miles (from 272)
On a LFP more or less important. If it was the case, Tesla user manual would of mention it.Is it true that you shouldn't charge the car to 100% if you aren't going to drive it the next day?
