Most people not aware of depth of discharge (DoD), with LFPs deeper the cycle quicker the degradation. I charge my LFP M3 to 100% all time time and keep it at 100% all the time. After 10000 Kms my degradation is only 0.4 and have full estimated range of 435 Kms.
The question is which will have less net overall degradation. A car going between 50 and 100% will have more age based degradation than the one going between 45 and 55. Unless you are just doing nothing but driving and charging all day every day. They report that age based degradation was 10-30% of degradation during their tests, but was that a test where it was constantly cycled?Here's a good finding, although these LFPs were considered "Graphite", "Sauer at al. reported that cycling degradation at 1C between 45% and 55% SOC was greater than between 50% and 100% depth-of-discharge (DOD)"
Do you keep it at 100% without driving for more than a day?Most people not aware of depth of discharge (DoD), with LFPs deeper the cycle quicker the degradation. I charge my LFP M3 to 100% all time time and keep it at 100% all the time. After 10000 Kms my degradation is only 0.4 and have full estimated range of 435 Kms.
OK, I’ve decided to go rogue again, but this time hopefully in a way that doesn’t piss off @AlanSubie4Life and @AAKEE. Haven’t charged to 100% for a month now, and plan to continue this until I actually take a long trip. I charge back up to 74% whenever I get down around 30-35 %. So perhaps I can serve as a cautionary tale for those who would consider the folly of not charging their own LFP’s up to 100%. When the time comes and I do have to charge to 100%, I will report back as far as what my new 100% SOC range is…
Interesting so i think it is better to charge it 100% all the time i guess. I wonder if keeping it at 100% soc if not driven same day will have any negative impact or battery degradation.OK that was posted April 10, and so I went around 3 months keeping the SOC between 30% and 74%. Today I charged all the way to 100% and the projected range at 100% was 245 miles. That would be an 8-mile loss (slightly more than 3%) from 10 months ago when the car purchased. 5300 miles on the car and the life time watt hours per mile currently sits at 229.
11,000 miles and mine is also showing 245 miles @ 100%. Was originally 253 miles when I first got the car. Is there any way to regain that 8 miles back?OK that was posted April 10, and so I went around 3 months keeping the SOC between 30% and 74%. Today I charged all the way to 100% and the projected range at 100% was 245 miles. That would be an 8-mile loss (slightly more than 3%) from 10 months ago when the car purchased. 5300 miles on the car and the life time watt hours per mile currently sits at 229.
Batteries lose range with time. All you can do to nearly stop it is park the car at 1% charge in a freezer and never drive it.Same question here. I tried an uneducated simulation of something I read in the sticky thread they have where an owner was repeatedly running his battery down to a single digit SOC, then letting the car sleep (and, I believe, allowing the car’s battery management system to re-evaluate its batteries). Apparently he did get quite a bit of his range back by doing that. But I got the car down to 5% charge yesterday, powered it down for 5 minutes, then left it sitting/sleeping for about 5 hours in the garage, before charging it up to 100%. For the past few months charging the car to 74%, it always stopped charging at 181 miles, and 181 miles is 74% of 245 miles. So all my uneducated efforts had zero effect on the projected mileage. I’ve pretty much resigned myself to the prospect that I won’t be seeing those lost 8 miles ever again…
My guess is yes, it would have negative impact, but to some potentially negligible degree like the car lasts only 12 years instead of 13, or something like that…
There are probably a few things to consider if you are concerned about minimizing degradation:Tesla recommends charging 100% at least once a week with LFP batteries which I believe is for BMS calibration due to LFP cells having a relatively constant voltage. With this in mind, to reduce degradation on the battery, would it be best to charge to say 70% daily then set it to 100% once a week and drive shortly after, or what would be the best charging practice to have the battery live the longest life possible?
Do you typically plug in daily?There are probably a few things to consider if you are concerned about minimizing degradation:
I only really do #1 above (occasionally #2, but usually charge to 100%), and tend toward #4 over #3 (which can be somewhat opposing to each other), and have not had to do any longer term storage. My car (with LFP battery) with about 6,500 miles is now showing 269 miles, down from 272 miles when new. At first, it fluctuated between 270 and 273 miles, but has been showing 269 miles at 100% for the last few thousand miles.
- Set charging to finish shortly before you drive off, particularly if charging to 100%. This is to minimize time parked at high state-of-charge.
- Charge normally to some level lower than 100% (preferably under 70% for LFP batteries, under 55% for NCA batteries based on the recently posted image), but charge to 100% only occasionally (once per week for LFP batteries; only when needed for NCA batteries).
- Charge frequently so that each charging session is smaller.
- When parking the car for longer periods of time, prefer having it in the lower state-of-charge range (but not so low that vampire drain will drop it to 0%).
- For longer term storage (where the vampire drain is more likely to drop it to 0% if unplugged), it may be best to plug it in with the charge target set to 50% (the lowest setting). For LFP batteries, charge up to 100% just before driving the car again to ensure that the BMS is correct.
Yes, this is a good idea since it keeps depth of discharge to a minimum which is good for all Tesla batteries. It also makes plugging in a habit which is desirable to ensure your car is always sufficiently charged. Bonus: recommended by Tesla.Do you typically plug in daily?
No, because I do not drive every day. I plug in the afternoon or evening before I need to drive enough that I want the car to be "full" at the beginning of the day.Do you typically plug in daily?
Do you have the 55kwh or the 60kwh?Most people not aware of depth of discharge (DoD), with LFPs deeper the cycle quicker the degradation. I charge my LFP M3 to 100% all time time and keep it at 100% all the time. After 10000 Kms my degradation is only 0.4 and have full estimated range of 435 Kms.
