ATPMSD
No issues with this. But if the only thing you will be using this for is the fridge, you will be better off using a 12v fridge as inverters are not terrible efficient, say only 50%. And as you noted you can avoid camp mode by wiring to the battery. If you do this be sure you include a fuse and make sure you can disconnect whatever you plug in - just use a standard 12v outlet.1. What does everyone think of this idea. Like I say, the little inverter works fine off of the 12 volt accessory so the current demand numbers are valid.
No. This is something that needs to be taken car of sooner than later.2. If I get a “replace the 12 volt battery” message, can I reset it myself.
3. I am assuming the car, even when asleep, will enable the DC to DC converter to replenish the 12 volt battery yes???
Yes
