Think of the % SoC display as a very accurate fuel gauge which displays your remaining energy ("fuel"), relative to the "full" value.
The only slight twist here is that unlike a fuel tank, the size of your energy tank when full reduces over time, particularly for the first year or two, as the battery capacity is reduced. (If you want to avoid this complication, just switch to "distance" display.) I believe this was the issue you were encountering in your original post (???). Anyway, the energy your battery holds is not really related to how you've driven in the past (to first order - exceptions might exist if you're REALLY abusing the battery, since that might lead to accelerated capacity loss, but probably not).
Your battery has just lost a bit of capacity, that is all. Perfectly normal. Your vehicle started at something around 340rmi (~75kWh, it's hard limited to that in "Europe" (
) rather than ~353 miles) and now it's down to 71kWh (322rmi) or thereabouts.
